chevy cruze 2012
Daltj1205
chevy cruze 2012
Post by Daltj1205 »
hello i just received my intune today and first thing i did was plug it into my computer to get the most recent updates andwhen i plugged it into my car first the tcm had an error i skipped that and then when i went into the tune it let me set all my stuff first and then when i went to build the tune it said an unexpected error has occurred please help im confused
info.xml
(2.19 KiB) Downloaded 390 times
ECM_55587117_Backup.grg
(108.09 KiB) Downloaded 355 times
Re: chevy cruze 2012
there is no tcm/tranny support for a Cruze.. so just skip the TCM part of the tune and it will install the ECM/engine tune no problem..
Daltj1205
Post by Daltj1205 »
i tried skipping the tcm and it just buffers at 0% while its building the tune and then it says an unexpected error has occurred then creates an error log and then continues to sit at 0% and does nothing
info.xml
(2.2 KiB) Downloaded 346 times
are you trying to adjust any parameters when you load the tune?
If so, please try resetting the params then load the tune that way and see if it works.
