AFR guage missing?
icepic
AFR guage missing?
Post by icepic »
2014 mustang V6 performance package.
trinity t1000
serial:6QN7S31-4
VERSION: v1r13l
everything i have read says i should be able to log AFR but i cannot find it and don't think it is available on my device? have found lambda commanded and reported, LTFT B1 & B2, STFT B1 & B2, but not seeing AFR in any of the menus. can't find anything online about this beside attaching an o2 sensor though analog and i shouldn't need to do that because my car has wideband o2's and a PID available. any assistance would be greatly appreciated, thank you.
Re: AFR guage missing?
Lambda reported is AFR, you should be able to convert it from Lambda to AFR.
icepic
Post by icepic »
ok thank you, so how can i make a gauge based off of lambda that reports AFR? is there a way to put the calculation into the lambda gauge to convert to afr?
icepic
Post by icepic »
figured it out, switched lamda display to AFR by clicking on gauge and changing display units.
icepic
Post by icepic »
ok this is off topic from post, but i can't seem to log AFR/lambda reported, only afr/lambda commanded shows in my logs, is there a reason for this? aside from horrible gas mileage, i sure am loving this thing! :-D
i am using dataviewer to look at logs, not sure if the program isn't seeing the AFR/Lamda reported values in the log, or if the trinity can't retrieve it from OBDII, only logging 8 parameters.
Return to “Trinity Ford Gas”
