2014 mustang V6 performance package.
trinity t1000
serial:6QN7S31-4
VERSION: v1r13l
everything i have read says i should be able to log AFR but i cannot find it and don't think it is available on my device? have found lambda commanded and reported, LTFT B1 & B2, STFT B1 & B2, but not seeing AFR in any of the menus. can't find anything online about this beside attaching an o2 sensor though analog and i shouldn't need to do that because my car has wideband o2's and a PID available. any assistance would be greatly appreciated, thank you.
AFR guage missing?
Re: AFR guage missing?
Lambda reported is AFR, you should be able to convert it from Lambda to AFR.
ok thank you, so how can i make a gauge based off of lambda that reports AFR? is there a way to put the calculation into the lambda gauge to convert to afr?
figured it out, switched lamda display to AFR by clicking on gauge and changing display units.
ok this is off topic from post, but i can't seem to log AFR/lambda reported, only afr/lambda commanded shows in my logs, is there a reason for this? aside from horrible gas mileage, i sure am loving this thing!
i am using dataviewer to look at logs, not sure if the program isn't seeing the AFR/Lamda reported values in the log, or if the trinity can't retrieve it from OBDII, only logging 8 parameters.
