"Update your vehicle to a supported CAL ID"
I have a stock 2006 Chrysler 300 SRT8 and I get this message when trying to go to the performance menu. I am currently running version v.1r13h. Need help thanks
Re: "Update your vehicle to a supported CAL ID"
connect the tool to a pc and open the dsdownloader, then when it connects to the tool it will present a calibration updater button, click that and it will download the file to the tool for you.
Ok I think I can shed some light on people having this issue. Make sure you close the DSDownloader programmer and reopen it. I was walking back and forth to the car. Only after I closed and reopened the program the calibration update tab appeared.mikel wrote:connect the tool to a pc and open the dsdownloader, then when it connects to the tool it will present a calibration updater button, click that and it will download the file to the tool for you.
Thank for the response
I've run into a similar issue after updating Trinity firmware. My vehicle is a 2006 Dodge Magnum SRT 6.1L
Using DSDL 2.2.2.11 to update firmware and updated to 1R13h. The update completed successfully.
Changed vehicle type to 2006 Dodge Magnum SRT 6.1L
Attempted loading a canned tune (Perf CAI 91oct) back to the vehicle and resulted with message
"CalID 04692392AD Not supported"
Called Diablosport support line and the tech advised changing vehicle type to 2010 Dodge Charger SRT 6.1L
The canned tune then loaded successfully.
So far , so good, but...
Checking Last Tune Written shows:
Perf CAI 91oct
PCM: 05030232AF
TCM: Not Saved
I don't see a "calibration updater button" after re-connecting the Trinity to a PC via DSDL 2.2.2.11 as mentioned in the above posts.
My concern:
I will be upgrading to the MOPAR Performance TCM (MTCM) soon and I want to be sure there will be no problems caused by not having the original TCM firmware image saved.
Will I be able to return to stock tuning if/when I need to without having a saved image of the stock TCM firmware in the tool?
I always reload stock tune for dealer service and (very importantly) for state smog inspections.
Perf CAI 91oct
PCM: 05030232AF
TCM: Not Saved
My concern:
did you call in about this today?
Yes i did, that's when i was told to select 2010 Charger SRT as vehicle type.
So, was that not the correct thing to do?
Can the trinity be returned to the previous firmware rev? There was no problem prior to the upgrade to 1R13h.
It's been a few days. Anyone have answers to offer?
bpulaski wrote: "CalID 04692392AD Not supported"
Perf CAI 91oct
PCM: 05030232AF
TCM: Not Saved
My concern:
I'm interested to hear back on these questions. Thanks.bpulaski wrote:So, was that not the correct thing to do?
I was under the impression that you had resolved this, if it is working there is no need to change anything.
I had asked some questions, any answers to offer?
there's no need at all to restore stock tune for vehicle emissions inspections.. no reason to..
Still need to return to stock tune:
- for dealer service
- pull the tuner to sell the car minus all mods
But that wasn't the only question, see above. Still would like your answers to those.
I suggest that info be added to your downloads page to clearly state when/why a user would want or need to update firmware.
That would save others some time and trouble since there is no need for most to do periodic updates.
I cant even get the v.1r13h for my car. under the downloads when I click it just brings me to another page and says error page.BCNorgard wrote:I have a stock 2006 Chrysler 300 SRT8 and I get this message when trying to go to the performance menu. I am currently running version v.1r13h. Need help thanks
Kyle Martin
colorado5.3
hi guys i'm new in the forum and new with the trinity my vehicle is a 2009 chevrolet colorado 5.3L V8 when connect the tool to the truck i got a message "calibration id not supported" i dont know how to post the log files to the forum so i just find this from my trinity i hope some one help me thanks
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM3 at 57600 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6QOF3D1-4'.
Part number = 'gm_can_gas'.
CROM version = 'gm_can_gas-1r13q 03/24/2016 11:09:21 AM boot3'.
Vehicle VIN = ''.
Vehicle Calibration = '12628994'.
Original backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are NOT supported.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is SUPPORTED.
Tool SUPPORTS multiple ECUs.
Tool reports 2 ECUs.
Multi ECU Backups : 0
Marriage VIN :
Tool ID :
Desc :
Multi ECU Tuning : 0
Server:
Vehicle VIN = ''.
Marriage VIN :
Tool ID :
Desc :
Server:
colorado5.3
wow has been 2 weeks since i bought my trinity and still unable to connect it and can't find help anywhere
