Mercury grand marquis 2008 speedometer +5%
Majvall
Post by Majvall »
Hi!
I used the advance tune 93octane, but now the speedometer shows +5%. It used to be exact on spot, compaired to GPS. How can i fix this?
Here in Sweden we have 95octane, is it possible to tune the car to 95?
Thanks /Peter
Re: Mercury grand marquis 2008 speedometer +5%
did you make any adjustments to the tune for axle ratio or tire size?
Please post the files from the tunes folder on the i2 drive.
Your 95 octane is rated differently but is very similar to our 91 octane fuel.
Majvall
Post by Majvall »
Hi!
First time i changed the tune to 91octane, speed limiter OFF and nothing else. This time i changed to 91 octane, speed limiter OFF and tire size 225/60 - 16. And the speedometer are still +5%.
DiabloMatt
Post by DiabloMatt »
Majvall wrote:Hi!
so you are saying the speedo WAS accurate untill you loaded the diablo tune?
Majvall
Post by Majvall »
Yes! Very accurate! At 50km/h the GPS are 50km/h, at 110km/h the GPS are 109km/h.
After the tune at 50km/h the GPS shows 47km/h and at 110km/h the GPS shows 104km/h.
/ Peter
DiabloMatt
try this tune...
Majvall
Post by Majvall »
Thank you. I will try it today.
I changed the paper airfilter to K&N and the exhaustpipe to Magnaflow, do i have to do any adjustments in the tune?
DiabloMatt
Majvall wrote:Thank you. I will try it today.
should not have too.
Majvall
Post by Majvall »
Hi!
I did try to install the speedofix file today, but i couldnt see it on the i2. I putt the file in same folder as the other tunes. Is it wrong folder?
/ Peter
yes, the file should not go in a folder, copy it to the root of the i2 drive.
Majvall
Post by Majvall »
I did that, but i can not find it in the i2. I run the 91 octane once again, but no differense. :crashing: :crashing:
Majvall
Post by Majvall »
Hi!
I did copy it to the root of the i2 drive, but i cant find it in my i2. I run the 91 octane once again, but no differense. Still +5%.
What happens if i change the settings on tire size to 17", would that fix the +5%?
/Peter
