2015 Dodge Charger R/T Road and Track Pack - 2 issues
Hey guys, just installed my PCM with the 91 octane canned tune, car pulls harder definitely, the issues are, I can't adjust the shifting firmness and the axle ratio. Every time i try i get this error:
Re: 2015 Dodge Charger R/T Road and Track Pack - 2 issues
please post the info.xml file from the i2 drive.
Here its is.
Did you figure out the problem Mike?
No, we are still investigating.
Ok good because i got a custom tune and i would like to adjust my axle ratio to my custom tune so i can get more out of it.
I dont mean to pressure, but is this figured out at all? Its a bit annoying having a tune and not having the right axle ratio the shifting firmness. Its almost useless having the tune without being able to adjust some of the key factors.
sorry, with the 8 speed there is no shift firmness option, it should not be there.
The axle ratio does not need to be adjusted for 8 speeds either.
Well the thing is, the 2015 Dodge Charger R/T comes with the 2.65 gears, the 2015 Dodge Charger R/T with the Super Track Pak has the 3.07 gears which is the one i have. I have to be sure the PCM and tune is corrected to the 3.07 gears.mikel wrote:sorry, with the 8 speed there is no shift firmness option, it should not be there.
it knows what your stock gears are, there is no need to tell it....
Fair enough. Are you guys planing to unlock the shifting firmness on the 8 speed transmissions?mikel wrote:it knows what your stock gears are, there is no need to tell it....
