Intune freezing
Re: Intune freezing
hello,
I have forwarded your flip file to your email.
Daniel Gomberg
Tech Support
Phone: (561)-908-0040
Fax: (561) 431-0429
Tech Support
Fax: (561) 431-0429
Re: Intune freezing
Didn't last long. Tried to make a few changes to the Torque Management settings, loaded tune and it then said that it had a failure and would need to create a failure log. Now I can no longer load anything.
Registry is;
0016A4
47092D
843DA0
9E7C0D
CBFAA5
Registry is;
0016A4
47092D
843DA0
9E7C0D
CBFAA5
dang wrote:hello,
Re: Intune freezing
Here are the new files:
- TCM_24250667_Backup.grg
- (15.54 KiB) Downloaded 1089 times
- ECM_12631165_Backup.grg
- (57.52 KiB) Downloaded 1130 times
- info.xml
- (2.24 KiB) Downloaded 1243 times
Re: Intune freezing chev cruze
Can someone help. 2015 Chevy Cruze 1.4l LTZ Whenever I try to tune it now it freezes and won't do anything. Please help. it always freezes once the intune says to turn the key and the tuner starts to load, but always ends up just hanging forever.
Re: Intune freezing
Hi
Whenever i try to install a tune, my device gets stuck at 94% (for over an hour) trying to backup the stock tune. Please help!
Re: Intune freezing
please update the tool on a PC and try it again.[email protected] wrote:Hi
adriansag_
Re: Intune freezing
So my Intune is doing the same how can i fix that?
I can load it up but as soon as the lil dile goes in circles it freezes ,help please!
Re: Intune freezing
My intune keep freezing when I want to tune my vehicle. What could I do?
Re: Intune freezing
me too please we need help its freezing in stage 1 when its reading the car backup ?
Re: Intune freezing
same thing here with freezing... registry reset pass?
657197
C6F6D5
8B57AA
78EC15
02AFED
657197
C6F6D5
8B57AA
78EC15
02AFED
kwhitleybfd
Re: Intune freezing
Anyone heard any more on fixing this issue? Having the same problems with it freezing. I did notice that although it froze at the end of the process of writing the 87 Octane tune, DOD or AFM on my 07 Chevy Silverado is now turned off which is an option I had set to be turned off. Don't know if the rest of the tune was successful though.
Re: Intune freezing
im using a in tune 1000 on my 08 Tahoe ltz 5.3 and it installed tune but when i try to go back to stock its says no pcm or it freezes up any help would be great
Re: Intune freezing
please give us a call with the tool powered up in the vehicle and we'll get you going.dmoore wrote:im using a in tune 1000 on my 08 Tahoe ltz 5.3 and it installed tune but when i try to go back to stock its says no pcm or it freezes up any help would be great
Re: Intune freezing
Well, add me to the list of freezing, for my intune DCX. My device freezes, just after I try to write a custom or any of the canned tunes. The recovery works fine and restores the original backup. 2013 Dodge Challenger 5.7L
The key is:
138CC0
3BCC9B
B6811F
8F026F
1E3EA9
Edit:
Never mind, the update worked. Re-tuned!
The key is:
138CC0
3BCC9B
B6811F
8F026F
1E3EA9
Edit:
lsteiner72
Re: Intune freezing
I'm having this same problem? Should I update and try again first or should I just call in? Number to call?
Lucas
Lucas
