Intune freezing
dang
Re: Intune freezing
Post by dang »
hello,
I have forwarded your flip file to your email.
Daniel Gomberg
Tech Support
Phone: (561)-908-0040
Fax: (561) 431-0429
oldcats
Re: Intune freezing
Post by oldcats »
Didn't last long. Tried to make a few changes to the Torque Management settings, loaded tune and it then said that it had a failure and would need to create a failure log. Now I can no longer load anything.
Registry is;
0016A4
47092D
843DA0
9E7C0D
CBFAA5
dang wrote:hello,
oldcats
Re: Intune freezing
Post by oldcats »
Here are the new files:
TCM_24250667_Backup.grg
(15.54 KiB) Downloaded 1090 times
ECM_12631165_Backup.grg
(57.52 KiB) Downloaded 1131 times
info.xml
(2.24 KiB) Downloaded 1244 times
shmigelz
Re: Intune freezing chev cruze
Post by shmigelz »
Can someone help. 2015 Chevy Cruze 1.4l LTZ Whenever I try to tune it now it freezes and won't do anything. Please help. it always freezes once the intune says to turn the key and the tuner starts to load, but always ends up just hanging forever.
Re: Intune freezing
Post by [email protected] »
Hi
Whenever i try to install a tune, my device gets stuck at 94% (for over an hour) trying to backup the stock tune. Please help!
Re: Intune freezing
[email protected] wrote:Hi
please update the tool on a PC and try it again.
adriansag_
Re: Intune freezing
Post by adriansag_ »
So my Intune is doing the same how can i fix that?
I can load it up but as soon as the lil dile goes in circles it freezes ,help please!
Phicao
Re: Intune freezing
Post by Phicao »
My intune keep freezing when I want to tune my vehicle. What could I do?
sketcher
Re: Intune freezing
Post by sketcher »
me too please we need help its freezing in stage 1 when its reading the car backup ?
MT83
Re: Intune freezing
Post by MT83 »
same thing here with freezing... registry reset pass?
657197
C6F6D5
8B57AA
78EC15
02AFED
kwhitleybfd
Re: Intune freezing
Post by kwhitleybfd »
Anyone heard any more on fixing this issue? Having the same problems with it freezing. I did notice that although it froze at the end of the process of writing the 87 Octane tune, DOD or AFM on my 07 Chevy Silverado is now turned off which is an option I had set to be turned off. Don't know if the rest of the tune was successful though.
dmoore
Re: Intune freezing
Post by dmoore »
im using a in tune 1000 on my 08 Tahoe ltz 5.3 and it installed tune but when i try to go back to stock its says no pcm or it freezes up any help would be great
Re: Intune freezing
dmoore wrote:im using a in tune 1000 on my 08 Tahoe ltz 5.3 and it installed tune but when i try to go back to stock its says no pcm or it freezes up any help would be great
please give us a call with the tool powered up in the vehicle and we'll get you going.
choc
Re: Intune freezing
Post by choc »
Well, add me to the list of freezing, for my intune DCX. My device freezes, just after I try to write a custom or any of the canned tunes. The recovery works fine and restores the original backup. 2013 Dodge Challenger 5.7L
The key is:
138CC0
3BCC9B
B6811F
8F026F
1E3EA9
Edit:
Never mind, the update worked. Re-tuned!
lsteiner72
Re: Intune freezing
Post by lsteiner72 »
I'm having this same problem? Should I update and try again first or should I just call in? Number to call?
Lucas
