Unable to update
RT_RZR
Unable to update
Post by RT_RZR »
I purchased a used intune tuner which is unmarried. The auto updater is giving me the following error:
"An unexpected error occured. Tool OEM is missing. Parameter name: OEM"
Here is my info.xml file:
<?xml version="1.0"?>
-<tool_info> <main svn="5122" sw_rev="1r02c" full_version="InTune-1r02c 08/15/2012 02:07:04 PM"/> <registration status="0" sn="IGO1KDF-2"/> <cal_id CM1="04692392AIke0v00" PCM="05094680AH"/> <restore bc="0" vin="2B3LA53HX6H474309" id="0"/> <system_db vin="1r01a" dtc="1r01a" info="1r01b"/> <db pid="1r01a" tune="unknown" mfr="DCX"/> <db pid="1r01a" tune="1r01e" mfr="FORD"/> <db pid="1r01a" tune="1r01k" mfr="GM"/> <license tuned="0" avail="1"/> <unsupported vin="2B3LA53HX6H474309" oem="DCX" calid="05094680AH"/> <updates count="1"/> </tool_info>
Let me know what I need to do so I can update the tuner. I will be using it on a 2006 Dodge Charger RT.
Re: Unable to update
please attach the info file
RT_RZR
Post by RT_RZR »
mikel wrote:please attach the info file
Here is the file as requested:
info.xml
(557 Bytes) Downloaded 417 times
RT_RZR
Post by RT_RZR »
Hey Mike,
Did you have a chance to look at my info file yet?
please save this file to the drive and let it reboot then try the udpater again.
cdrom-1r01w.itf
(3.97 MiB) Downloaded 556 times
RT_RZR
Post by RT_RZR »
I transfered the file to the tuner. I let it reboot and tried to update it again. I am still getting the same error as before.
Here is my new info file:
info.xml
(557 Bytes) Downloaded 372 times
RT_RZR
Post by RT_RZR »
Hey Mike, have you had a chance to look at the new info file?
they were closed yesterday for company outing..
they'll be back monday..
try loading this file, dont worry about the updater for now.
dcx_tunes-1r01f.itf
(12.88 MiB) Downloaded 461 times
RT_RZR
Post by RT_RZR »
I loaded the file to the tuners drive & let it reboot. I hooked up the tuner to the car and when I proceeded to tune the car I got a screen saying the PCM might need a calibration update.
I am still unable to update the tuner as I am still getting the same error as before.
Anything else we can try?
Here is the new info file
info.xml
(555 Bytes) Downloaded 371 times
RT_RZR
Post by RT_RZR »
Hey Mike, did you have a chance to look at the new info file?
RT_RZR wrote:Hey Mike, did you have a chance to look at the new info file?
save this ot th eintune drive, let the tool import it then load the update to the car, then you can tune it.
2B3LA53HX6H474309_05094680al.drg
(433.4 KiB) Downloaded 508 times
RT_RZR
Post by RT_RZR »
It worked. I was able to tune the car. Thanks for all your help.
