2010 Ford Ranger 2.3 Spark knock retard
Am I missing something on my intune, or is there no PID in the datalog for seeing how much timing is being pulled? All I see for timing is the spark advance for number 1 cylinder and overall timing advance. It seems there is no way for me to tell if timing is being retarded at all.
Re: 2010 Ford Ranger 2.3 Spark knock retard
under the Misfire section, there should be a knock retard parameter you can add to the logging pid's...
I'm just now getting back to this. Under the misfire section i only have two options, high byte-cumulative number of misfires, and low word of cumulative misfires. I don't see anything for spark knock or for timing being pulled.
Anyone else run into this or am I just blind? I don't find any parameters for spark knock or timing being pulled. I can't advance the timing of I can't tell if it's being pulled...
there should be one there, can you try connecting a laptop and streaming it through DV?
That's where I've looked for it, connected to dataviewer.
- IMG_20160701_123527118.jpg (6.62 MiB) Viewed 2403 times
