adjustable parameters on 2016 challenger hellcat
What parameters are you supposed to be able to adjust with the i2010? I'm not seeing the fan settings.
Re: adjustable parameters on 2016 challenger hellcat
fans, rev limit, idles speed, WOT fuel, WOT timing, speed limiter, seeing those?
I've got everything but the fans. I've updated the tuner but still not there. I tuned my 2015 scat pack and could adjust them but with the new car it's all there just no fan settings.
Odd, we'll look into that.
Any updates guys?
https://www.dropbox.com/s/l6hqvzmelhczp ... l.ITF?dl=0aw148751 wrote:Any updates guys?
drop that onto the intune drive and let it load. Should be there after that.
Insert Clever comment here...
No fan settings yet. I downloaded what you sent and updated my i2 and it still has everything but the fan settings. Restored the stock tune and tried it again, no change. Changed to 91 octane tune and more of the same.
Post the info.xml file.
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="14U7Z5KODI"/>
-<applications count="5">
<application rev="2r01j" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2r01e" name="gui"/>
<application rev="2r01c" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2r01c" vin="2r01g" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" tune="2r01c" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM"/>
</databases>
<last-connected vin="2C3CDZC92GH217432" mfr="DCX" calid="68286870AC"/>
<last-connected calid="05035471AC"/>
-<licenses tuned="1" available="1">
<license vin="2C3CDZC92GH217432" mfr="DCX" PCM="68286870AC"/>
</licenses>
<reg reg="rs4HU90xtClUUCGY11NWrcPPllf6rMzngBjrDBeck246Pc+3IlhtumE+7XHw5igcO55FuEFJo/bGVlbSJl9pI4iv/HEEpLSt9xvColVnVoqWeDbv44Gfh0/kbx0E43XstN+wQ4F7KT0tTu+vzxhq4C+1J4XMvYa63B1Vxartwo/Q7q/F9q/BediamBbjvsOGxIQEKHrXl3RvDavzhZ90f7dS/JoMZDWCmtj+mYsGwsCcInE3WYcE1Zm7Va5kMEvkFJ/4vvEVDLJVYy4lvjMOQr9MfY8JNql1b2NCAmgAE4m6rhNIjsiIxvtOLDtHS96hoGox14Sz180w4UvnLJu0R1u9TMbC3ATsg1GbAH/INdPEjwGUriPEOuPDum18Nivl+bqnwDx+KAQrlDkH4dpjR0YyH/LsdMSCIymJPolbt3jG/xlrA6h6tCMZoXsE8XITR3rvF2nKyJjvBVwsWnPBKeha7gvHf5gUMRYma2BU9HQCKjqtdlOfyVdTH5/xTEVR6C48WceFNJ0+pOq/DFzx5T4hB1xk7FDkyfP8E9iNT69HnWWekxWmVdmUTF7XUMsptJjPjcPKLAynJN7FerxMcAIYVT2G4kybz4i5jN+H7wkGNT5TLd/ZuorNMNlr9y2tnwZtAXEqh5NmcNadRJ2sNfBMxpjyMhYZ+rdcb9yuN194pS8NLu/dBhL5t5tMU/aRjEnbPf6rZ5l6Frei/PDJh+P4JA6a6qbfwvwPk8QwdXNdX33apeydGW1Z8/U2mScs1rxhy8kvHNGUGsLmHCANw60YhcwMs8aXsu8ilM2dNpG6X2+TblA/l2OL3WqSzR2fsFL7zz+pJbaImFfyyg+n3ec8ISwIfky7fh7dslE7wNeebvgAwbom+nR+gAmhx4saftMGk7Dluf/ZSA16aTC/1ernpNXW40cbo+mgP0gl2nbiq8ioy4k4xiVipQKiAGAnTCvCA69tBSVzLXy7cI8X7Mkkj0m1sgwh52n9a+6ZW2sB0g+oKjNMQbRKJL8+CELM7pF4SSBmG3J3BzGyNXHqyXEJcEQOKpQYPeU3lRxRO0g3s+WShOOecCuCf06maUuPL67Fy1qduOjinTpTiEAm5uEUv5TtDEVHQH+DJMhaJyKmTpaOX9GcgpXLqadtm0/n1gQjrSDjhMbotz8ywyA7OdYP1N1Uli9nWj3REETLtqmC2Y5VieK17RV1duV8xHjDY5WxAekI74iUE4Eax1YXBh0bhyd3bkvUUEeJJpN2ywxsrcov1JIf0D5HHFiBNtT0nDBASu7micWpf4qSNAf8U9ytef4bkAPqAXuA7Jpn4pdK"/>
</tool_info>
-<tool_info>
</applications>
</databases>
</licenses>
</tool_info>
you do not have the uypdate loaded that he provided, please reload it, restore the stock tune then check the params again.
i downloaded it again. still no fan settings.mikel wrote:you do not have the uypdate loaded that he provided, please reload it, restore the stock tune then check the params again.
-<tool_info>
</applications>
<database pid="2r01cc" tune="2t01dl" mfr="DCX"/>
</databases>
</licenses>
<reg reg="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"/>
</tool_info>
Can you post your actual info.xml please?
I thought that was the info.xml file. Where do I get it?sohfast94 wrote:Can you post your actual info.xml please?
he wants you to attach the actual info file, rather than the contents of the file
<tool_info>...</tool_info>
