Intune freezing up will not load canned or factory tunes.
Colestripes
Post by Colestripes »
Vehicle is a 2008 Chevy Silverado with the 5.3 engine.
I was running Diablo tune for longest time turned it back to stock then tried to load the 87
Octane tune and it freezes up. I have updated it tried restoring to stock but once it asks for ignition to
Be turned on I do that and then it freezes with the little wheel. Any ideas anyone.
Re: Intune freezing up will not load canned or factory tunes
please post the files form the tunes folder here then we'll reset and get you going.
Colestripes
info.xml
ECM_12651461_Backup.grg
TCM_24245713_Backup.grg
Colestripes
i really don't know how to copy and paste them. i'm on a Mac also
Colestripes
Hope this worked
info.xml
(3.34 KiB) Downloaded 196 times
Colestripes
(15.8 KiB) Downloaded 203 times
Colestripes
(57.8 KiB) Downloaded 176 times
Colestripes
(57.8 KiB) Downloaded 202 times
perfect, lets reset it now.
go to settings/advanced/tech suport/advabnced/registry reset and type out the key it displays there and post it here and wait for my reply to proceed from there.
Colestripes
7EF56B
E6A435
DD6D10
2893F8
E9EE51
Colestripes
Was this what you needed sir? Thanks.
Colestripes
Here is the requested info again. Thank You
7EF56B
E6A435
DD6D10
2893F8
E9EE51
Mak25
Post by Mak25 »
@Colestripes, did this work?
Im having the exact same issue. Except, I have the 87 tune in the truck now. It gave me some weird error code towards the end and then froze. It took the 87 tune and some additional stuff, but aborted the tranny firm shift. Now it wont recognize the truck at all.
My truck is the same as yours also.
Colestripes
I actually went to emailing a technician and he was
Very helpful. My programmer simply froze. And yes
It worked. He sent me a reset code and it works flawless actually faster
And better than ever. Now if I could figure out whinny truck sounds like a tank with the
Ac on I'd would be like new. I purchased the programmer after the motor have out at 140 thou and had
To install a new engine. No more dod for me.
Mak25
Post by Mak25 »
@Colestripes, Nice! So did you have a tune in the truck when your unit froze or was the truck stock at that point?
