10 RAM PICK UP RIPP SUPERCHARGED
bhps
Post by bhps »
I HAVE AN 10 RAM PICK UP WITH A RIPP SUPERCHARGER ON IT. THE VEHICLE STALLS WHEN YOU TURN THE AC ON EVEN IF YOUR LIGHT ON THE THROTTLE WHEN MOVING. I HAVE SCAN TESTED IT AND FOUND THAT WHEN THE AC IS ON AN YOU MOVE THE THROTTLE THE APP VOLTS MOVE BUT THE TPS VOLTAGE DOES NOT CHANGE. I HAVE CHANGED THE THROTTLE BODY NO DIFFERENCE. ALSO CHECK THE TUNE AND MADE A COUPLE CHANGES TO IT WHEN I FLASH IT IN IT WORKS FINE BUT AFTER A WEEK OR SO OF DRIVING IT STARTS STALLING AGAIN ANY IDEAS I WILL POST THE FILE THANKS BOB
bradys ripp 13.drg
(87.21 KiB) Downloaded 576 times
AllUSA
Re: 10 RAM PICK UP RIPP SUPERCHARGED
Post by AllUSA »
You can try this.
bradys ripp 13 idle up.drg
(87.3 KiB) Downloaded 578 times
http://www.doctortuned.com
DYNO TUNING.
Custom Tuning GM, Dodge, Fords
843-246-5832
