10 RAM PICK UP RIPP SUPERCHARGED
I HAVE AN 10 RAM PICK UP WITH A RIPP SUPERCHARGER ON IT. THE VEHICLE STALLS WHEN YOU TURN THE AC ON EVEN IF YOUR LIGHT ON THE THROTTLE WHEN MOVING. I HAVE SCAN TESTED IT AND FOUND THAT WHEN THE AC IS ON AN YOU MOVE THE THROTTLE THE APP VOLTS MOVE BUT THE TPS VOLTAGE DOES NOT CHANGE. I HAVE CHANGED THE THROTTLE BODY NO DIFFERENCE. ALSO CHECK THE TUNE AND MADE A COUPLE CHANGES TO IT WHEN I FLASH IT IN IT WORKS FINE BUT AFTER A WEEK OR SO OF DRIVING IT STARTS STALLING AGAIN ANY IDEAS I WILL POST THE FILE THANKS BOB
- bradys ripp 13.drg
- (87.21 KiB) Downloaded 578 times
Re: 10 RAM PICK UP RIPP SUPERCHARGED
You can try this.
- bradys ripp 13 idle up.drg
- (87.3 KiB) Downloaded 579 times
