can't adjust torque management
2005silverado
Post by 2005silverado »
i can't adjust the torque management settings? thanks
hof740
Re: can't adjust torque management
Post by hof740 »
You can only do that in custom tune mode and only for WOT torque reduction I believe. Obviously its under the TCM sectionThese tuners are pretty limited but good for the average guy who wants a little more power from his stock truck. The real tuning for major mods you have to pay someone like Lew for
2005silverado wrote:i can't adjust the torque management settings? thanks
here you go, upshift abuse mode off.
aw73
Post by aw73 »
my 2004 chevy silverado 2500 6.0l doesnt shift any firmer no matter what shift pressure i have it set at, does this mean the torque management is still on? i see it in the menu but there is nothing there when i select it.
post your tune files.
aw73
Post by aw73 »
heres my tunes.
AllUSA
Post by AllUSA »
http://www.doctortuned.com
DYNO TUNING.
Custom Tuning GM, Dodge, Fords
843-246-5832
aw73 wrote:heres my tunes.
it is already disabled in this tune.
AllUSA wrote::
if you are looking for the same fix please post the backup file as well.
aw73
Post by aw73 »
mikel wrote:
AllUSA wrote::
i think he posted that for me.
aw73
Post by aw73 »
if it was already disabled then doctortuned must have done something different cause it does seem to shift a little firmer.
AllUSA
Post by AllUSA »
Yes I changed a few parameters. should feel better. Let me know if you need anything else.
DYNO TUNING.
843-246-5832
aw73
Post by aw73 »
AllUSA wrote:Yes I changed a few parameters. should feel better. Let me know if you need anything else.
ok thank you!
aw73
Post by aw73 »
there is still a big pause from 1st to 2nd when i am at half throttle. 2nd to 3rd to 4th seems fine. if i am giving just a bit of throttle it seems fine. not sure about wot. what do you think that could be?
cbaker22681
Post by cbaker22681 »
I cant adjust Torque management either it is empty no matter what tune I use. Can you check mine as well and disable it if it is not already.. Also no matter what settings I use for shift times, pressures, WOT, Partial, etc I cant tell any difference in the shifts. Most posts I have seen say they have a choice when tuning the diablo tune to do a firm shift. My tuner gives me no option when applying the tune for any firm shift.
Any help would be appreciated..
Truck is a 2000 Silverado 4.8L 4spd Auto
Attached are the current tune files. I reinstalled the default diablo tune and only changed the injector slope. So any help with the torque management and other adjustments would be great and very appreciated
