Problem updating my i-1000-DCX
rajansingh241994
I tried updating my I-1000-DCX because with the latest update to my PCM the old tune I had for my 2013 dodge charger rt daytona no longer is compatible. When updating the tuner I get the following message on my tuner: "The current firmware revision (1r03x) cannot be replaced by the firmware package within group_update_0." After I press continue on my tuner it says "failed to update.itfg". Some help would be greatly appreciated! Thanks in advance.
Re: Problem updating my i-1000-DCX
load this to the intune drive and let it import it then you can run the updater from there.
- intune-1r03y.itf
- (1.82 MiB) Downloaded 300 times
rajansingh241994
Ok thanks! After doing this will my tuner be ready to be plugged into my car to load the tune back onto my charger or will I have to redownload the tune?
