Potentially fried cpu with the t1000
I have a 13 dodge charger with a Trinity t1000 the other day the tuner only had 2 red lights lit and as I drove to get to work my car started severely misfiring...has anyone else have this problem? I can't get any scan tool to connect to my vehicle now
Re: Potentially fried cpu with the t1000
if the tool had a problem and locked up it should not have any effect on the car, does it run properly now?
No the car is misfiring over 3g rpm under that it is fine. It only started when the tuner locked up
try a battery reset, disconnect it and drain voltage then reconnect.
I did that, cleared the code but there still stored in the computer. I was able to get my personal can tool to link to the car the codes It's throwing are U0002 and p0304
P0304 is a legit misfire code, seems perhaps there was something that happened to the car that needs to be addressed.
