Shifting question... wont shift (5th) WOT
Tristar
Post by Tristar »
Wondering if i can attach a picture from DataViewer some how .
I forgot to say that when the car used 3rd gear at full , it changes to 4rt only for a short while before it switches back 3rd again
for about 1- 1,5 second , and only then back to 4rth . Its just like a 1.5 sec lag in acceleration after 90 mpr .
It could be nice if i could set the 4rth gear change at WOT lets say at exactly 85mph and no way it would change back to 3rd unless its 84mph .What i am trying to say is if gearbox could upshift gears at WOT at certain speeds like 2nd -25mph ,3rd -60,
4rt-85 , fifth i dont know never get there at WOT , regardless of what rpms engine is running at .
Is that possible ? I know that i can change shift points with Predator + 20 - of what i have now ,but I am fine with
shift points which i have at the moment , i just do not want rpms interfere with them , because i know for sure that the 3rd gear
kiks back in when rpms reaching 5800 or what ever limit i set with Predator .
Tristar
Post by Tristar »
O, I am sorry , I just realize that the topic is - wont shift (5th) WOT and i am talkin about wont shift properly to (4th) WOT
Warped3d
Post by Warped3d »
hey my problem was solved.... kevin sent me the tune fix and i don't know what he did to make my car shift perfectly, but props to him and hopefully he will be able to share the parameters he fixed on here with the others having this problem.... I tried it out today and man it made me smile!!!! no down shifting nothing just smooth sailing!!!!!
Tristar
Post by Tristar »
Today i put JLT Induction Tune into the car , without Firm Shift , the same thing , car gets to the 3rd gear at WOT with
no problem , then it changes to 4rt (only for 2 seconds ) , back to 3rd (1 - 1.5 second) , then back to 4rth and keeps
going as normal , that happens only at WOT .
Can someone help me please .
Car is 2006 Ford Mustang V6 Automatic
Revision v.8r08
4 Digit Cal Code or Strategy - FBCE053
Warped3d
Post by Warped3d »
yea tristar i had the same problem, and after kevin gave me the custom tune...my car sails smoothly !!! now i can WOT 1-4 no werid shifting patterns nothing, but speed!!!!!!! so you just might wanna wait till u can get a hold of one of the tech guys to work on the tune for you :\
Tristar
Post by Tristar »
Thanks Warped3d for shearing your expirience , it is nice to know that it could be fixed .
Can someone from techsupport help me , Please .
I use JLT 93 Octane Firm Shift or BamaChips 93 Octane Race Tune , same problem like Warped3d .
In few words , car gets to the 3rd gear at WOT with no problem , then it changes to 4rt (only for 2 seconds ) , back to 3rd (1 - 1.5 second) , then back to 4rth and keeps going as normal , that happens only at WOT .
Car is 2006 Ford Mustang V6 Convertible Automatic
Revision v.8r08
Cal ID - FBCE053
rubenisrael52
Post by rubenisrael52 »
Hey kevin i heard that the problem was fix and i want to know if you can send me that custom tune please and explain what i have to do... my email is [email protected] please.. send it thanks
kmac1
Post by kmac1 »
For you guys having this issue please email me [email protected]
Please include the tune that is in the vehicle when this occurs, the Predator part #, revision #, and any changes you made in the custom parameters.
To get the tune that is in the car you must go into the Custom Tune menu in the Predator and hit Export Last Tune Written, then get tune file from Predator on the DS Dowloader software. The problem tune must be the tune that was written to the car last also.
I'm trying to cover all the bases on this issue so we can fix it in a future revision.
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
rubenisrael52
kevin, so that means that every time we change the tune we have to send you the tune that we are going to put in???
kmac1
Post by kmac1 »
rubenisrael52 wrote:kevin, so that means that every time we change the tune we have to send you the tune that we are going to put in???
I am trying to repair it so the issue is gone and you won't have to email me for future tuning.
Whoever emails me now allows me to verify the issue in other calids so I don't miss any for the future update.
Kev
kmac1
Post by kmac1 »
I see the issue. I'll be fixing all the tunes I find with this problem and you should have this fix in the next update very shortly...
Kev
Kevin MacDonald
Calibration
www.jpcracing.com
ssmotor
Re: Shifting question... wont shift (5th) WOT
Post by ssmotor »
Hey Kevin, I'm running into this same problem with a 2006 Mustang. I used an up to date Intune i1000 with the 93 octane tune. What parameters need to be changed?
PCM_FBCE0B3_Backup.frg
(471.95 KiB) Downloaded 332 times
PCM_FBCE0B3_LastTuneWritten.frg
(471.56 KiB) Downloaded 359 times
AcuDye Auto Tune
Putting the tune back in tune up
DiabloMatt
Post by DiabloMatt »
see if that helps
PCM_FBCE0B3_shift.frg
(433.01 KiB) Downloaded 346 times
Return to “Predator Ford Gas”
