Intune i-1000 freezing
Tazilla
Post by Tazilla »
Intune i-1000 been working fine i went to change tune on my 05 mustang gt and it said an update might be needed and if i wanted to check i clicked yes instead of no so now i get a warning "Disk Check This can take up to 30 minutes" my only option is continue which i do and the progress circle goes around for a while then stops.
Tazilla
Re: Intune i-1000 freezing
Post by Tazilla »
Was using a windows 10 computer plugged it in to a windows 7 computer and it updated but now when i plug it in to the car it says vehicle not supported.
please post the info.xml file from the intune drive so we can check it out.
Tazilla
Post by Tazilla »
Here is the file, thanks.
info.xml
(1.63 KiB) Downloaded 462 times
Tazilla
Post by Tazilla »
Any ideas?
you just need to update the device then it should be fine.
Tazilla
Post by Tazilla »
Is there a different way to update besides plugging into computer?
No....updating requires a PC.
Tazilla
Post by Tazilla »
Is there some instructions somewhere on the forums? I thought i updated it but maybe i did something wrong.
Return to “General Support”
