Install loop
pogdl
Install loop
Post by pogdl »
Recently updated the i2. It went through the update to the press continue to reboot. Once rebooted it installs the update again, over and over stuck in this continuous loop.
Re: Install loop
pogdl wrote:Recently updated the i2. It went through the update to the press continue to reboot. Once rebooted it installs the update again, over and over stuck in this continuous loop.
save this to the i2 drive, et it import then run the updater again and it will be done.
