Diablo intune freezing up
Esprit6286
Re: Diablo intune freezing up
Post by Esprit6286 »
So I went to program the 93 octane tune and it got to 15% and froze. Than " service stabilitrak" light came on. I called Diablo and after 25 min on hold I gave up and turned the key off. When restarted every light on the dash was on and I was able to get it home but in like a limp mode. Luckily I plugged it back in and returned the stock tune and it's fine. I'm too nervous to try again. 2016 Silverado 5.3
could there have been a low voltage situation?
06blackgxp
Post by 06blackgxp »
I'm having the same problem with freezing trying to tune? I started to tune my 07 Escalade and it was at 100% and said something to to effect of experienced an error. Since then I can't get into tuning mode. When I select tune vehicle it starts to spin then freezes up spins again for a second then freezes completely. Registry reset key is 873263 D4071C 5C2520 41A414 671D4F. Thanks!
06blackgxp wrote:I'm having the same problem with freezing trying to tune? I started to tune my 07 Escalade and it was at 100% and said something to to effect of experienced an error. Since then I can't get into tuning mode. When I select tune vehicle it starts to spin then freezes up spins again for a second then freezes completely. Registry reset key is 873263 D4071C 5C2520 41A414 671D4F. Thanks!
please post the backup files from the device before we reset it.
06blackgxp
Back up files
TCM_24242131_Backup.grg
(39.08 KiB) Downloaded 264 times
ECM_12614104_Backup.grg
(61.49 KiB) Downloaded 265 times
josh6980
Post by josh6980 »
I'm having the same problem with freezing trying to tune? I have on occasion needed to charge my battery before or after tuning/retuning. Is this a possible problem?
TCM_24237497_Backup.grg
(13.29 KiB) Downloaded 263 times
ECM_12614095_Backup.grg
(52.6 KiB) Downloaded 312 times
info.xml
(2.08 KiB) Downloaded 259 times
06blackgxp wrote:Back up files
go to settings/advanced/registry reset and type out the key it displays and post it up, and leave tool on that screen until I reply with instructions to proceed.
josh6980 wrote:I'm having the same problem with freezing trying to tune? I have on occasion needed to charge my battery before or after tuning/retuning. Is this a possible problem?
please start a new thread, it gets hectic trying to post files for 2 different customers in the same thread.
06blackgxp
DD47BD FAFB41 20B2AA 00C5AA 3E8798
click next then enter this
C868E27B877493B9
then Ok and it will reset.
06blackgxp
I did the reset now it wants me to email the stock tunes. I have them listed up a few posts
06blackgxp wrote:I did the reset now it wants me to email the stock tunes. I have them listed up a few posts
save this to intune drive and let tool import it then go to the vehicle and click tune vehicle and it will load this t set pcm back to stock,then we may have to repeat for tcm.
CTRL_12614104_UPDATE_1GYFK66837R395828.grg
(57.4 KiB) Downloaded 280 times
06blackgxp
Back up and running. Amazing what the tune did for it, Thanks!
