Jeep GC 5.7L 2005 "not supported"
vasek
Post by vasek »
I just bought a new intune i2 for my Jeep GC 5.7L 2005, connected with my PC and registered, then updated. However, everytime I connect to my Jeep and select "tune vehicle" the intune states that "This vehicle is currently not supported... an update may be required. Please plug the i2 into a PC to download any updates.". When I try new update, it shows "Attempted to read 2 files, but they were not found: -> Tune/"myVin"/PCM_UnknownBackup.drg, -> Tune/"myVin"/TCM_UnknownBackup.drg". I tried updating on 3 computers and nothing changed. Please, help.
2 missing files
2 missing files
info.xml
my info.xml
(1.97 KiB) Downloaded 275 times
Re: Jeep GC 5.7L 2005 "not supported"
are there files in your i2 drive in the tunes folder?
If so can you post them here?
vasek
Post by vasek »
No, tunes folder is empty.
more info
more info
diablo 2.jpg (237.2 KiB) Viewed 7827 times
tunes folder
tunes folder
device folder
device folder
vasek
Post by vasek »
1
1
info.xml
last info
(1.97 KiB) Downloaded 281 times
save this to i2, let it import the file then load update to vehiucle then you can tune.
vasek
Post by vasek »
I appreciate your 50444 posts but i do not see any files and where i should import that file? :D Thank you.
marko250
Post by marko250 »
mikel wrote:save this to i2, let it import the file then load update to vehiucle then you can tune.
The file is missing Mikel.
marko250
Post by marko250 »
I'm a father> vasek
marko250
Post by marko250 »
With the supplied file .drg already it works, thanks Mikel. I can not activate the TPMS in i2, update is not? It works on my car?
When first connected car started only four cylinders and jumped errors P1411/P1414/P1416/P1417(1/4/6/7cylinder).Helped> disconnect the battery.
marko250
Post by marko250 »
Menu TPMS does not exist. Update does not work, four files are not installed, watch video 1:43min fail-
https://www.youtube.com/watch?v=w3oPsN7AJAw
, send files(/tune+info)
info.xml
(2.1 KiB) Downloaded 283 times
PCM_56044555AN_Backup.drg
(38.49 KiB) Downloaded 300 times
PCM_56044555AN_LastTuneWritten.drg
(38.33 KiB) Downloaded 284 times
Please help Mikel :D
marko250
Post by marko250 »
Hallo :(
marko250 wrote:Menu TPMS does not exist. Update does not work, four files are not installed, watch video 1:43min fail-
info.xml
there is no tpms option for this application unfortunately.
I dont understand what you say is not working, it seems you have the tune installed.
marko250
Post by marko250 »
Excuse me for English, I do not speak English.
So TirePressureMonitoringSystem is not in i2 for my car, OK? Unrealized update does affect the function of i2?(video 1:43min)? Thank you Mikel.
The seller claimed the opposite and I bought it only because of it Tire size and Tire pressure ON/OFF :(
:punisher: Seller text:
Application:
2006-2010 Jeep Commander 4.7L/5.7L V8
2005-2014 Jeep Grand Cherokee 3.6L/4.7L/5.7L/6.1L/6.4L SRT8 V8
2005-2014 Jeep Wrangler 3.6L/3.8L/4.0L
inTune i2 Performance Programmer for Jeep
Part Number i2012
GET THE BEST PERFORMANCE UPGRADE FOR YOUR CHRYSLER
Upgrade your horsepower in minutes with our inTune i2Power Programmer. It is easy to install and plugs right into your vehicle’s OBD-II port. Our tuning team maps out all of the i2’s tunes for your exact car or truck. Our goal is to make the biggest power gain, with the largest choice of performance options. The i2 features the latest electronics too; find out more about what makes the i2 the best handheld tuner available today!
HELP YOUR WRANGLER CLIMB OVER ANYTHING
Tuning for 2005-2015* Jeep Wrangler TJ and JK
Since the debut of the Wrangler it was built to go anywhere, but let’s face it, after modding it for off-roading with bigger tires and gears, it needs a boost. The i2 programmer gives your Wrangler the power it needs on or off-road, as well as complete control over its electronics. You can calibrate for bigger wheels and tires, new gears, disable the TPMS, and a ton more! The i2 also gives you options to adjust the idle for winches or any other aftermarket electronics you need for the trails or camping.
InTune i2 Programmer Key Jeep Wrangler Tuning Features:
Add 10-15 HP, 15-20 TQ**
Adjustable tire size
Adjustable gear size
Adjust Idle for Accessories
Turn off TPMS
Check and clear DTCs
