Totally lost on updater missing?
darkh20
Post by darkh20 »
Everytime I plug into windows computer and open the ignition software it says I need an update. Flies through a couple screens then says you can either purchase more licenses or unplug you are up to date. Then when I plug back in it just keep repeating like its not updating. Not sure if I am missing something but here are a couple screenshots. And no matter how many times I try to go through the link to activate the wifi on my intune 2020 on the ignition program I fill out the form but it never sends the wifi unlock to device? Unless there is something else to do for that as well? Thanks in advance I have had this for over week now and finaly get a free time to call in for support to find out they are closed today grrr...
darkh20
Re: Totally lost on updater missing?
Post by darkh20 »
I should also add when I first tried to do the update brand new out of the box thing it was on a mac. Wasn't getting anywhere with that so I switched over to windows 10 laptop. If it is somthing as simple as a factory reset on the unit but even at that where to even start...
darkh20
Post by darkh20 »
Or if anyone happens on this post could double check your info on yours to see if everything is actually updated? Everytime i plug it in it tries to grab 1 file for update goes hrough the process and then bam doesnt actually install that file. something update_0.
darkh20
Post by darkh20 »
Come on 22 views and no one can take the time to confirm?
staripley
Post by staripley »
I see the same on mine as well . In addtion WIFI does not enable either. Even after registering and receiving the hardware from Diablo. Alng with all the updates.
darkh20
Post by darkh20 »
Well talked to tech support was assured my unit is all up to date. Thumbs up there and loaded a tune seems to work, pretty noticeable difference 87 octane. Was told I needed some kit as well for the wifi to work along with some kind of software update when I install the barrels to the lines, now if yours did nothing and wifi still don't work then it doesn't give me much hope mine will be a smooth transition. But so far so good with everything else will keep this updated for the near future on my results.
darkh20
Post by darkh20 »
Just because I hate to start a topic and have no conclusion. All is well, diablo tech added my s/n to the database plugged into ignition and pulled in the update for the wifi. Everything now works. Fwiw once I reached out for help diablo had all my issues resolved within 2 days can't complain about that, thanks much!!
