15+ ZF8 TCM support now available on i2/i3
The latest i2/i3 updates add support for 2015+ 8 speed TCM models.
There is one preloaded perf trans tune, and custom tuning is an option as well.
Nightshade
Re: 15+ ZF8 TCM support now available on i2/i3
Post by Nightshade »
mikel wrote:The latest i2/i3 updates add support for 2015+ 8 speed TCM models.
Great news.
Do you know what was adjusted in the canned perf trans tune? it's raining here so won't be able to test it too aggressively. ;)
pressures and some torque management.
Nightshade
Updated my i2. Plugged it into the truck.
Vehicle is not supported.
checked for more updates, nothing found. (both wifi and connected to ignition)
info.xml attached.
Still have my custom tune on the truck from Sean...
west27
Post by west27 »
What not the 2014!!?? :cry:
Will the 2014 8 speed ever be supported? Been waiting for this for a while now....
Nightshade wrote:Updated my i2. Plugged it into the truck.
info.xml attached.
Its not showing an update request here.
Can you try restoring the stock tune then try reloading and agree if it asks for an update at that point?
Nightshade
info.xml attached.
I can't restore stock tune now that it was updated though. I click on the 'tune' and it comes back right away that the vehicle isn't supported.
Is there a way to restore stock tune?
Maybe we should be restoring stock tunes before updating the device?
info.xml attached.
lets reset it.
go to settings/advanced/tech support/advanced/registry reset and type out the key it displays and email to me to make it quick.
mlitsch @ powerteq.com
Please reference what this is in regards to when you send the email.
Nightshade
mikel wrote:
Nightshade wrote: I can't restore stock tune now that it was updated though. I click on the 'tune' and it comes back right away that the vehicle isn't supported.
lets reset it.
Email sent. Sorry, I didn't see this message right away.
am sure I missed you for today.. so don't worry about the one I sent you actually.. since the key is different every time it is run... not leaving it plugged in and turned on at that screen till Monday. :-)
Mindycandy
Post by Mindycandy »
How long does the update take? Hooked it up to the computer and it's been checking/installing updates for half an hour now
chillidic
Post by chillidic »
Mine updated in about 10 minutes... installed new tune in 2015 charger R/T, awesome nice hard shifts. Love it !!
Mindycandy wrote:How long does the update take? Hooked it up to the computer and it's been checking/installing updates for half an hour now
please post your info file.
You can disable wifi to get past this.
Rob
Post by Rob »
Sorry to jump in, but would you be able to tell me if the perf TCM went thru with mine? MDS off as well(if possible)
Rob wrote:Sorry to jump in, but would you be able to tell me if the perf TCM went thru with mine? MDS off as well(if possible)
it is married to your pcm and tcm from what I can tell, yes. You would have had to select a tcm tune and saw it read and write the TCM...
Rob
Post by Rob »
Thanks mike! Gonna try this baby out now
