15+ ZF8 TCM support now available on i2/i3
The latest i2/i3 updates add support for 2015+ 8 speed TCM models.
There is one preloaded perf trans tune, and custom tuning is an option as well.
Nightshade
Re: 15+ ZF8 TCM support now available on i2/i3
Great news.mikel wrote:The latest i2/i3 updates add support for 2015+ 8 speed TCM models.
Do you know what was adjusted in the canned perf trans tune? it's raining here so won't be able to test it too aggressively.
pressures and some torque management.
Nightshade
Updated my i2. Plugged it into the truck.
Vehicle is not supported.
checked for more updates, nothing found. (both wifi and connected to ignition)
info.xml attached.
Still have my custom tune on the truck from Sean...
info.xml attached.
What not the 2014!!??
Will the 2014 8 speed ever be supported? Been waiting for this for a while now....
Its not showing an update request here.Nightshade wrote:Updated my i2. Plugged it into the truck.
info.xml attached.
Can you try restoring the stock tune then try reloading and agree if it asks for an update at that point?
Nightshade
I can't restore stock tune now that it was updated though. I click on the 'tune' and it comes back right away that the vehicle isn't supported.mikel wrote:Its not showing an update request here.Nightshade wrote:Updated my i2. Plugged it into the truck.
info.xml attached.
Is there a way to restore stock tune?
Maybe we should be restoring stock tunes before updating the device?
lets reset it.Nightshade wrote:I can't restore stock tune now that it was updated though. I click on the 'tune' and it comes back right away that the vehicle isn't supported.mikel wrote:Its not showing an update request here.Nightshade wrote:Updated my i2. Plugged it into the truck.
info.xml attached.
go to settings/advanced/tech support/advanced/registry reset and type out the key it displays and email to me to make it quick.
mlitsch @ powerteq.com
Please reference what this is in regards to when you send the email.
Nightshade
Email sent. Sorry, I didn't see this message right away.mikel wrote:lets reset it.Nightshade wrote: I can't restore stock tune now that it was updated though. I click on the 'tune' and it comes back right away that the vehicle isn't supported.
am sure I missed you for today.. so don't worry about the one I sent you actually.. since the key is different every time it is run... not leaving it plugged in and turned on at that screen till Monday.
Mindycandy
How long does the update take? Hooked it up to the computer and it's been checking/installing updates for half an hour now
Mine updated in about 10 minutes... installed new tune in 2015 charger R/T, awesome nice hard shifts. Love it !!
please post your info file.Mindycandy wrote:How long does the update take? Hooked it up to the computer and it's been checking/installing updates for half an hour now
You can disable wifi to get past this.
Sorry to jump in, but would you be able to tell me if the perf TCM went thru with mine? MDS off as well(if possible)
it is married to your pcm and tcm from what I can tell, yes. You would have had to select a tcm tune and saw it read and write the TCM...Rob wrote:Sorry to jump in, but would you be able to tell me if the perf TCM went thru with mine? MDS off as well(if possible)
Thanks mike! Gonna try this baby out now
