Having a issue with the T2 on my 05 neon 2.4
Yesterday I updated my tuner on ignite I keep getting this error and a endless start up loop. This did not happen before I updated the tuner only after.
I Have a new battery installed so I know it can’t be the battery and I’ve checked all wires.
Please help. I never get any response on this form
Sn 201191375
Flashing screen or not enough voltage error
Re: Flashing screen or not enough voltage error
Just a quick update my t1000 powers up fine on it but it’s married to another vehicle. My t2 is for this car
Does it seemto boot up properly on USB or in another vehicle?
It does boot up by the usb on the computer or a usb plug. I havnt tried it on another vehicle because the only other one I have that’s currently running was a ford and wasn’t sure if it would do anything.
But the t1000 powers up when it’s plugged into the srt4 neon but not my t2 it just constantly flashes the screen and doesn’t power up
please power it up in the ford and see if it boots properly.
Yes it does power up on the ford correctly.
well...this is pointing to an issue with the SRT4. Really odd though. Id check all the OBDII port wiring
I checked the wiring and it looks exactly like the stock set up with the same pins in their location.
Also I checked the voltage and it’s at 12v in the obd2 port
