INTUNE LOST ORIGINAL GM TCM BACKUP FOR MY CAMARO SS...
shaunmherman
Post by shaunmherman »
I recently purchased 3 ECM Custom Tunes, which also includes 1 TCM Custom Tune for my 2011 Camaro SS… THE TUNES ARE GREAT! My problem is with my iNTUNE I-1000. I decided to install the canned tunes to compare; fortunately, night and day difference!
However, when I went to reinstall the custom tunes, the intune locked up. As a result, I was stuck with the ECM & TCM canned Diablo Tunes. After a call to Diablosport, they had me send them both of my original backups (ECM & TCM). They reset the tool and sent me a new file to return the ECM back to stock, as well as a 2nd file to return the TCM to stock.
PROBLEM: The ECM file returned the ECM to the Original GM Backup successfully. However, the TCM file did not work; as a result, I am stuck with my stock ECM Tune & the Diablo Hard Shift TCM Tune... Everything that Diablosport has tried so far has failed to return my TCM to the Original GM TCM Backup... As a result, they suggested that I have Chevrolet reflash the TCM back to stock.
Here's where it gets tricky... Because Diablosport's Hard Shift TCM Tune showed the same Calibration ID as the GM TCM Calibration ID, the reflash was blocked and aborted during the process of the dealer reflashing the TCM. They in fact told me that the TCM already had a GM Calibration. Since I didn't believe them, they took me to the vehicle and started the process again. After the normal bell chimes and dings, sure enough, a message appeared on the computer stating that your are trying to install the same calibration that is already present, which is not allowed... Status BLOCKED! However, the Tunes File on the iNTUNE clearly show the Original ECM Backup and the Diablo TCM Tunes are installed. Whenever I try to tune after a Diablosport reset, the tool states that the TCM is tuned by Diablosport… Please contact them and send the file...
So here's my issue: I have a 91 Octane Custom Tune, a 93 Octane Custom Tune, a 98 Octane Custom Tune, and a TCM Custom Tune... (All of which worked GREAT and I recently purchased)… However, I have an iNTUNE that wont allow me to use them; in fact, I cant even return the TCM to stock. While the guys at Diablosport have been hands down professional and courteous, nothing to date has worked. I need help? I would purchase a new tool if it will solve my problem but I don't want to buy it and end up still stuck with the same problem? I figure the new tool will also recognize a Diablosport TCM Tune and not allow me to do anything? Any suggestions?
Please Help!
Shaun :cry:
Re: INTUNE LOST ORIGINAL GM TCM BACKUP FOR MY CAMARO SS...
This is a tricky spot.
The dealer CAN load the same cal, they just need to mess with it to make it happen. Its not part of the standard process.
Any chance you are local to us in Central Florida?
shaunmherman
Nope... Detroit Michigan. Will the i3 have the same issue if I buy the new tool? What do you suggest? One of your colleagues seems to think a new tool will resolve the issue?
Yes, an i3 should work fine.
shaunmherman
THANKS FOR GETTING ME SQUARED AWAY!!! YOU GUYS ARE GREAT!!! :D :drivingbad:
Shaun Herman
Ismail droubie
Post by Ismail droubie »
Hello, thank you for your concern,
I have a Dodge Ram 2010 model 5.7 hemi engine.
I was lucky to purchase Diablo trinity 1000 adding on cool air intake, exhaust headers and high performance manifold..
Few weeks ago I had a problem with my cooling fan and at the Dealer they thought it’s software problem and they reset the operating system with out using the diablo trinity device..
And sicne then I can not use the chip and it’s features any more and stuck in the stock software .. I tried many ways and I could not ..
Please advice if there is any tip gets it back to work..
thank you
