However, when I went to reinstall the custom tunes, the intune locked up. As a result, I was stuck with the ECM & TCM canned Diablo Tunes. After a call to Diablosport, they had me send them both of my original backups (ECM & TCM). They reset the tool and sent me a new file to return the ECM back to stock, as well as a 2nd file to return the TCM to stock.
PROBLEM: The ECM file returned the ECM to the Original GM Backup successfully. However, the TCM file did not work; as a result, I am stuck with my stock ECM Tune & the Diablo Hard Shift TCM Tune... Everything that Diablosport has tried so far has failed to return my TCM to the Original GM TCM Backup... As a result, they suggested that I have Chevrolet reflash the TCM back to stock.
Here's where it gets tricky... Because Diablosport's Hard Shift TCM Tune showed the same Calibration ID as the GM TCM Calibration ID, the reflash was blocked and aborted during the process of the dealer reflashing the TCM. They in fact told me that the TCM already had a GM Calibration. Since I didn't believe them, they took me to the vehicle and started the process again. After the normal bell chimes and dings, sure enough, a message appeared on the computer stating that your are trying to install the same calibration that is already present, which is not allowed... Status BLOCKED! However, the Tunes File on the iNTUNE clearly show the Original ECM Backup and the Diablo TCM Tunes are installed. Whenever I try to tune after a Diablosport reset, the tool states that the TCM is tuned by Diablosport… Please contact them and send the file...
So here's my issue: I have a 91 Octane Custom Tune, a 93 Octane Custom Tune, a 98 Octane Custom Tune, and a TCM Custom Tune... (All of which worked GREAT and I recently purchased)… However, I have an iNTUNE that wont allow me to use them; in fact, I cant even return the TCM to stock. While the guys at Diablosport have been hands down professional and courteous, nothing to date has worked. I need help? I would purchase a new tool if it will solve my problem but I don't want to buy it and end up still stuck with the same problem? I figure the new tool will also recognize a Diablosport TCM Tune and not allow me to do anything? Any suggestions?
Please Help!
Shaun
