Hello;
I have just installed a new T2-9345 on my 2010 Challenger RT 5.7L.
I did the software update off my Mac and all went fine. After installing it in the car and navigating around the screens with no issues, allowed me to clear a fault I created when I started the car with the cold air sensor disconnected earlier this winter.
When I went to the tuning page I received a fault saying;
"There are control devices in this vehicle that are currently not supported. An update may be required. Connect your device to a PC and run the update agent client to download the update."
The first thing I suspected was the PO had installed a Sprint Booster3 on the gas peddle. I disconnected and tried again. No change, same fault.
So I have now plugged back into my Mac to check for an update where nothing seems to be happening.
Any idea on what could be causing this? I believe the PO had done a dyne tune a few years back. He had installed an Edelbrock intake with fuel rails, larger throttle body, headers, MDS packs, and I have recently deleted the resonators.
Any help would be appreciated.
New T2 9345 install
Re: New T2 9345 install
ALL GOOD;
I had to log out of the update screen to get the T2 to restart the update software. Once that was done a quick update was applied, saw the car vin number come up quick as it finished. I was then able to get into the tonight software and load the Diablo Tune....just need spring to show up to go for a rip....
Mark
Ontario Canada
Ontario Canada
good deal.
I have the same issue but no matter how many times I update the tuner it always says the same thing when I plug it into the car. Is there any other way to fix this or am I doing it wrong ?
