Intune i2 vehicle not supported
DirtySRT4
Re: Intune i2 vehicle not supported
Post by DirtySRT4 »
Ok I called and spoke to someone about sending in the tuner he said it's covered under warranty because I can't drive the car because I can't switch tunes and I was able to plug my buddy's intune into my car and hit vehicle info and it brought the Cal I'd and vin right up in seconds his is older so I couldn't try swapping cables but it is indeed the tuner that won't read the car
OK, give us a call and we'll set up an rma to send it in.
DirtySRT4
Post by DirtySRT4 »
It was sent to you guys for repair can't wait to be able to drive the car again thanks again
DirtySRT4
Post by DirtySRT4 »
It said it was delivered on Monday the 27th can you let me know when you will be sending it back out thanks
it was processed today and is being replaced, should ship out today.
DirtySRT4
Post by DirtySRT4 »
Ok thank you let me know when it ships and if there is a tracking number thanks
DirtySRT4
Post by DirtySRT4 »
Ok I received the new tuner now do I just load my backup and tune files from my computer to the tuner ? Because the car still has a tune on it because I wasn't able to swap it back to stock before I sent it in ?
DirtySRT4
Post by DirtySRT4 »
Ok the new tuner works but it's saying it's been previously tuned buy a Diablo tuner how do I go about fixing that ?
DirtySRT4
Post by DirtySRT4 »
Ok my old tuner i2 wouldn't connect to the car which has a custom tune on it so I sent it in and you guys sent me a new one now how to I set it back to stock tune to be able to use the new tuner when you guys have the old one that wouldn't connect to the car ?
DirtySRT4 wrote:Ok the new tuner works but it's saying it's been previously tuned buy a Diablo tuner how do I go about fixing that ?
connect to pc and update it and it will download a stock tile, then go back to the car and load the update to the pcm to set it back to stock, then start fresh.
DirtySRT4
Post by DirtySRT4 »
It updated over WiFi is that the same ?
yes
DirtySRT4
Post by DirtySRT4 »
Ok it did the calibration update and plugged it into the car and it went threw it's process now I loaded my custom tunes do I need to load my backup and last time written too or no before I go and put my tune in
