Need to downgrade my trinity T1000
So I plug my trinity T1000 into my 12 Jeep wrangler JK superchargered with a magnuson TVS1320, and it says my trinity is not supported. Says I need to downgrade to version AF instead of AH... how do I go about doing that??? Please help me!!!
Re: Need to downgrade my trinity T1000
Lets back up a touch..
is this the tool you use to program this truck?
is it currently tuned and running properly?
Yes it is
On june 05, 2017, you posted to blk01stng with a similar problem, that he needs to “connect to pc, open DSDL and let it connect to the tool then click the cal updater button when it appears “. The question is, can I do the same????
Please respond asap, regards
This is what appears on Trinity
- 09A3FE6F-8749-4D19-ABFF-807463915B7B.jpeg (117.86 KiB) Viewed 10386 times
Any notice about this??? Regards
could the vehicle have been flashed by a dealer since you last programmed it?
I dont understand how its suddenly not supported if it was married to this vehicle.
Yes it was flashed by a dealer and after that the message appears. So what do you recommended to do about it
you'll need to give us a call to have the device unlocked.
if you go to the dealer, put the stock tune back in the pcm first
Can I Connect The cal to a PC, open the DSDL let it connected and push the updater button?
I’m in Mexico City and for me would be easier to have the instructions by writting instead of speaking. Please what information do you need to unlock the devine?
I can call you by my cell phone, can you give me the Numbers, please?
I’ll try to contact you usan the number 5619080040 but I can’t. Is that number correct ?
Hi please need the password in order to unlockw the tool an later update it
This is the key letters:
CF3D-029A-697A-560A-D610
And my Emali is: [email protected]
Regards
Regards
