Dataviewer not responding to my analog inputs
jd40
Post by jd40 »
I installed an AEM EUGO and the gauge works just fine but when using the diablo analog cable with my intune i3 the gauge doesn't move off the minimum setting (which is 8.5:1 AFR) I have the red wire to connected to the white and the black to the brown. Also the ground is grounded in the same spot as the gauge. I've tried both analog inputs 1 and 2 and tried all different wiring combinations with no success over the past 2 weeks and am getting very frustrated. Is my wiring wrong? Or is it a software issue.
Re: Dataviewer not responding to my analog inputs
load this to the root of the i3 drive and then try again please.
jd40
Post by jd40 »
mikel wrote:load this to the root of the i3 drive and then try again please.
That fixed it, thank you
great, we'll get this rolled current asap.
