I have an 06 Charger RT, had 9r03 version with no problems. It says that I need the latest update and refers me to www.diablosports.com/dcx, then gives my calid#.
Also, i tried to install latest downloader Ver. 1.9.9.4, but get an error saying it cant overwrite msvcp71.dll in the system file, i tried to delete but does allow me access. I went with the prior version again and that installed fine. Not sure what the heck is going on, never had problem with any updates since release of product.
Any help would be appreciated. Thanks
Having Problems Loading u7135-9r04
Re: Having Problems Loading u7135-9r04
Did John make 1.9.9.4 a production release? If not, they might not be supporting it. If you're going to use it anyway try this.KRAZZZI wrote:Also, i tried to install latest downloader Ver. 1.9.9.4, but get an error saying it cant overwrite msvcp71.dll in the system file, i tried to delete but does allow me access. I went with the prior version again and that installed fine. Not sure what the heck is going on, never had problem with any updates since release of product.
I think the files are in Windows\system32. You cannot delete them. You can rename them
Note that I said files. While you're there rename msvcr71.dll too. You just haven't got to that one yet.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
RE: Re: Having Problems Loading u7135-9r04
I am getting the same .dll issue as well...
That works with ease as well thereQuick wrote:Did John make 1.9.9.4 a production release? If not, they might not be supporting it. If you're going to use it anyway try this.KRAZZZI wrote:Also, i tried to install latest downloader Ver. 1.9.9.4, but get an error saying it cant overwrite msvcp71.dll in the system file, i tried to delete but does allow me access. I went with the prior version again and that installed fine. Not sure what the heck is going on, never had problem with any updates since release of product.
I think the files are in Windows\system32. You cannot delete them. You can rename them. Do something like rename msvcp71.dll -> msvcp71.dll.orig
I had this issue, and just clicked abort on the pop up and it finished the 1,9,9,4 install....
Quick wrote:KRAZZZI wrote:Note that I said files. While you're there rename msvcr71.dll too. You just haven't got to that one yet.
I didnt realize the second file. I renamed the original and i thought i was receiving the same error on the same file, but it was the above file that came up. I didnt catch the 'r' in it. Worked like a champ. Thanks
Now if I can only get the predator to download into my charger, we'll be good.
Re: RE: Re: Having Problems Loading u7135-9r04
err, you guys must be replacing those files for a reason right?mikel wrote:I had this issue, and just clicked abort on the pop up and it finished the 1,9,9,4 install....
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
The calibration update should be no prob once you have DSDL up and running, just connect it, make sure the tool is on 9r04, then do the cal update.KRAZZZI wrote:Quick wrote:KRAZZZI wrote:Note that I said files. While you're there rename msvcr71.dll too. You just haven't got to that one yet.
I didnt realize the second file. I renamed the original and i thought i was receiving the same error on the same file, but it was the above file that came up. I didnt catch the 'r' in it. Worked like a champ. Thanks![]()
I have a feeling it is trying to replace a file that is already there, thus the fact that ignoring it allows it to finish the install...Quick wrote:err, you guys must be replacing those files for a reason right?mikel wrote:I had this issue, and just clicked abort on the pop up and it finished the 1,9,9,4 install....
