Diablesport i3 — throttle boost inop
Hi. 2004 dodge Ram 5.7. Been using the i3 for years. Plugged in today after 4 yrs in glove box. Throttle boost showed 20% — as I left it years ago. I updated the unit … had two firmware updates. After the updates, I am not able to change throttle boost. The screen for throttle boost comes up, but no matter what I press, it will not change from 0%. Did the new forward updates disable this feature? Thx.
Re: Diablesport i3 — throttle boost inop
can you attach the info.xml file from the i3 drive here so we can check this out?
i sold my PEDDLE COMMANDER and bought the i3 platinum with the understanding that i would have complete control over my throttle like with the PC... im not able to increase the throttle what so ever and as i understand the MAX is 20% (which im not sure what that feels like as increase but im guessing not much..) .. so im lookin for a Tune that matches the throttle boost of the PC.. so like +80% of stock throttle response, something like that.. ( on the :diablo tune: w 87 octane 07 charger V6) .. if that could be arranged id be happy w this product right now i am not.. thanks in advance..
20% in the tune is a LOT, those values provided with throttle boosters are arbitrary. if you added 80% to the throttle table you'd be WOT at like 10% throttle.keegs wrote: Mon Jul 24, 2023 10:27 pm i sold my PEDDLE COMMANDER and bought the i3 platinum with the understanding that i would have complete control over my throttle like with the PC... im not able to increase the throttle what so ever and as i understand the MAX is 20% (which im not sure what that feels like as increase but im guessing not much..) .. so im lookin for a Tune that matches the throttle boost of the PC.. so like +80% of stock throttle response, something like that.. ( on the :diablo tune: w 87 octane 07 charger V6) .. if that could be arranged id be happy w this product right now i am not.. thanks in advance..
Id urge you to try it at 20% (we already add 15% in the tunes so thats 35% total) and if it not enough, grab the last tune written file, rename it, copy it back to the i3 drive as a custom tune then add another 20% to it
Ok ill give it a try.. it wont let me increase throttle sensitivity with the tune active (diablo tune) ...so where do i find this tune youre talking about??
or u mean like custom the tune i have on it right now so i can add more throttle..?
how do i do this i cant figure it out, how do i do that rename the file?.... and is the diablo13 platinum able to disable the EGR??mikel wrote: Thu Jul 27, 2023 4:05 pm20% in the tune is a LOT, those values provided with throttle boosters are arbitrary. if you added 80% to the throttle table you'd be WOT at like 10% throttle.keegs wrote: Mon Jul 24, 2023 10:27 pm i sold my PEDDLE COMMANDER and bought the i3 platinum with the understanding that i would have complete control over my throttle like with the PC... im not able to increase the throttle what so ever and as i understand the MAX is 20% (which im not sure what that feels like as increase but im guessing not much..) .. so im lookin for a Tune that matches the throttle boost of the PC.. so like +80% of stock throttle response, something like that.. ( on the :diablo tune: w 87 octane 07 charger V6) .. if that could be arranged id be happy w this product right now i am not.. thanks in advance..
Id urge you to try it at 20% (we already add 15% in the tunes so thats 35% total) and if it not enough, grab the last tune written file, rename it, copy it back to the i3 drive as a custom tune then add another 20% to it![]()
you open the i3 drive on your pc and then the tunes folder, then the folder with your VIN.
In there is a file names last_tune_written.
rename it as _throttle or similar, then save it back to the root of the i3 drive and the device will import it as a custom tune. Once the throttle boost param is fixed, you can add another 20% to that tune.
