05 Magnum R T
Discuss Predator 2 for Chrysler vehicles
Re: 05 Magnum R T
Karp wrote: Wed Jul 12, 2023 1:53 pm Thanks, I have one coming from Hemituner. What about updating my p2 for the i3?
give us a call, 561-908-0040
Hemituner TCM should be pretty awesome :)
Karp
Re: 05 Magnum R T
Post by Karp »
Ok got a preprogrammed TCM from Hemituner. Put it in and viola the car is Fixed! I returned the P2 tuner and have the i3 coming.
Re: 05 Magnum R T
Karp wrote: Wed Jul 26, 2023 7:41 pm Ok got a preprogrammed TCM from Hemituner. Put it in and viola the car is Fixed! I returned the P2 tuner and have the i3 coming.
glad to hear it!
Karp
Re: 05 Magnum R T
Post by Karp »
Ok, about 100 miles and the car failed. Kept getting u110b code. Kept resetting. Had to have car towed, i3 Platinum not much help. It's telling me that I have used up my tunes WT?.
Re: 05 Magnum R T
Sounds like the isue is related in some way to the TCM. Seems it was not uncommon with the Mopar TCM
https://www.lxforums.com/threads/code-u ... nt.249666/
Id suggest reaching out to AJ to see what he suggests there.
As for the i3, what do you mean, is it telling you there are no remaining licenses?
Can you attach the info.xml file from the i3 drive here?
Karp
Re: 05 Magnum R T
Post by Karp »
The i3 will not let me tune. Just scan. Says have no tunes left. Im back from my fishing trip now. Going to put the factory TCM back in the car. And try turning it. But the i3 won't update. Had it on the computer for hours. No love!
Karp
Re: 05 Magnum R T
Post by Karp »
Got it updated. Put factory TCM back in set to 3.06 gear still no love.
Re: 05 Magnum R T
id stick with the ZAJ TCM and do not make any changes to the gear or tire settings while it is installed in the car.
Karp
Re: 05 Magnum R T
Post by Karp »
Still the same result. I am ready to i
Wave the white flag and get 2.82 gears for the car. This has gone on long enough.
Karp
Re: 05 Magnum R T
Post by Karp »
And this i3 likes to freeze up and do nothing. Anytime it wants to.
Re: 05 Magnum R T
what is the exact issue now?
I thought it was ok with the new tcm?
Karp
Re: 05 Magnum R T
Post by Karp »
Back to codes U110B , P700, P731 and the Hemituner shifts to neutral, car won't move. Have to put factory TCM on to move in limp.
Karp
Re: 05 Magnum R T
Post by Karp »
I updated the i3 yesterday. Hemituner had me install the 91 tune, and it will freeze on a screen and do nothing. Have to unplug it,
Re: 05 Magnum R T
So you never did any programming while the tcm was installed, but it wont work at all?
You try initializing it?
As for the i3, not sure, I am not familiar with any freezing issues currently, give our tech team a call and we'll check it out.
Return to “Predator 2 for Chrysler/Dodge/Jeep/Ram”
