u7191 disabling o2 codes
blackenedss87
Post by blackenedss87 »
Can the u7191 tuner disable 02 codes for putting a hogan hi-flow cat downpipe on a 2006 monte carlo ss, or do I need a custom tune?
thanks,
Shaun
RE: u7191 disabling o2 codes
Yes, the tune will handle this.
blackenedss87
Its been a while and my monte ss has been running great, but recently I have been getting the p0420 code even on the diablo tune. I thought that the diablo tunes disabled the rear o2 sensor. I can clear the code in the obd2 section but it keeps popping back up after about a week or so. What could be the reason for this code popping up?
2006 MCSS
Blacker than Wesley Snipes, Loaded
Mods
K&N AirCharger, Magnaflow Catback with Res Delete, Hogan DP, Diablo u7191, MSP Poly Mount
supercatxr7
Post by supercatxr7 »
You need to have Diablo make you a custom tune that turns off the codes. I have an 06 SS as well and put the Hogan pipe on and got the code PO420. Diablo had to turn the codes off with a custom tune.
2006 Monte Carlo SS 5.3 V8
U7191
My bad, thought the tool had the option to disable, but yeah, email me a copy of the backup file and we'll take care of it.
blackenedss87
Ok, I'm busy right now but I should have time to send you the tune this weekend.
2006 MCSS
Mods
blackenedss87
Ok Mike I sent you and email. Am I supposed to send you a copy of the diablo tune that's currently in the vehicle or the original backup of the stock tune? I attached both.
Ledif
Post by Ledif »
Hello Mike I sent you a email regarding the same concern
Re: RE: u7191 disabling o2 codes
Ledif wrote:Hello Mike I sent you a email regarding the same concern
Ok, lets see here...your email is titled 'Predator GTO LS2 U7191'.
The issues in this thread are centered around an LS4 powered vehicle.
The GTO tunes are set up to disable the rear O2 sensors already, but I dont see how this is even a question if you have the tune installed, as you should have no rear O2 related codes.
blackenedss87
RE: Re: RE: u7191 disabling o2 codes
Hey Mike,
I have a different tune that I need the p0420 code disabled. I have emailed it to you. Also, could you throw in some TCM support while you're at it :D
2006 MCSS
Mods
Re: RE: Re: RE: u7191 disabling o2 codes
blackenedss87 wrote:Hey Mike,
LOL, will have the tune back shortly...
