volant is a pos. i just found 2 toothpic size holes in it
pawngod
Post by pawngod »
well...just got through running a log to dial in the ltft's and installing the new tune and for some reason decided to check out the volant...just to be sure...as i had read post about leaks can cause problems...i found 2 holes in the plastic tube near the tb....i dont know how i missed them when i installed it.....put some silicone to seal them up.....either way...after the new tune and fixing the leaks....i can no longer hear the kr i had been experiencing.....feeling better about that issue ...i guess i had better run a new log after fixing the holes in the volant......the hole is in a seam where they put the tubes together. now i am not sure who to complain to about the volant the place i bought it from or go through volant?? anyway it just stinks i gotta ugly spot of red silicone on the side of the tubing
08 sierra denali 6.2l awd, volant cai, aero 3535 muffler, diablosport.
CANUCKPREDATOR
RE: volant is a pos. i just found 2 toothpic size holes in
Post by CANUCKPREDATOR »
kinda good news/bad news
i'd talk to the people you bought it from. find out volant warranty. probably find your receipt. if its the tube i'd think it shouldn't be a big deal to exchange. are the holes after the filter? could you have sucked in dirt?
pawngod
Post by pawngod »
the holes are right before the throttle body on the side where the seam is just behind the gasket at the tb...i am sure it could get dust in the hole...i went straight for an oil change after fixing the leaks
Grumpy_Aero_Guy
Post by Grumpy_Aero_Guy »
Great catch. At least you have an answer.....
DSLogRedux.com
Grumpy_Aero_Guy
Re: volant is a pos. i just found 2 toothpic size holes in
pawngod wrote: anyway it just stinks i gotta ugly spot of red silicone on the side of the tubing
You can buy clear silicone. Re-DO it, get some flat black model paint and touch over it, if the red drives ya ntus.
Take a few digi-pics and sent it to Volante and give 'em a call. Always possible ya got a CAI that was kitted wrong or something... ??????
DSLogRedux.com
Return to “Predator GM Gas”
