01 v6 stang axle ratio
v6procharged
RE: 01 v6 stang axle ratio
ok. well is it setup to run the 11 lbs? just making sure, dont wanna mess nothing up ya know.
Yeah it will take 11 psi. I would like a datalog at 9psi first though...
Insert Clever comment here...
v6procharged
would you like to see the 9psi with the new tune or the one its got now?
The 9psi with the new tune.
v6procharged
alright will do as soon as i get home and load the tune onto my tuner. what timing do you have just by chance?
Uhhh. 12-13 degrees up top.
v6procharged
ok. just curious. what exactly is timing? do yall have a forum that explains all that stuff?
Go to www.howstuffworks.com type in engine.
v6procharged
alright, been there before, but didnt think about it.
v6procharged
ok i logged the gas acceleration WOT, is that the one you wanted? tryin to figure out how to load onto the computer.
You have PM.
v6procharged
alrighty, replied.
v6procharged
i didnt know if it had the right tune because it had the same name as the last one. also im running 93 octane if you need to change something. my 2-3 shift didnt go to the redline, im pretty sure it shifted at 4xxx, why would it do that?
Converter lock. Not shift. You gave me the right tune.
v6procharged
i meant the one you sent me was the same name as my last one so i didnt know if it installed yours or not....so what does that mean? converter lock....and also resent the log.
