I have a 2007 Z06 and the 7194 Predator. The stock tune has been saved in the Predator and the Predator tune has been loaded in the vehicle, so the pair is "married". Later a tune was loaded into the vehicle via HP Tuners. I want to run the Predator tune. I do not have access the the HP Tuning device.
So, my question:
Can I use the Predator to overwrite the nonstock, nonPredator tune in the vehicle? Can I do it directly, or should I reload the stock tune from the Predator, THEN load the Predator tune.
Confused in ABQ.
Overwritng a NON Predator tune
RE: Overwritng a NON Predator tune
oooh, that could be trouble...
you should have restored the original backup BEFORE you got a HP/dyno Tune installed...
No problem.
Just use the Predator to restore the backup file, and all will be well.
Mike
Mike
really?? the user manual for mine says that doing that or applying a tune to a non-factory tune could cause severe engine damage...
If it has a non factory tune on it now, then we restore the factory tune over it, we are back to square one with a stock tune on the PCM and a reset Predator.
Yes, but that would be the new 'backup' file.
