New beta for unsupported 04 and 08, tune changes as well
johan
Post by johan »
Well we have a feeling it might be a hardware issue with that Predator itself.
So it would have to come back here for us to check it.
If you want e-mail me and i will help you with the rma process as we want the Predator to go to engineering instead of repairs, we can prolly send you a new unit out once we get this one in.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
JPMichaels
Post by JPMichaels »
Does the new update (9t02) have shift control for the 04 Rams???? Thanks JP
johan
Post by johan »
JPMichaels wrote:Does the new update (9t02) have shift control for the 04 Rams???? Thanks JP
Nope not yet...
Diablosport INC
need-a-cage
Post by need-a-cage »
I am loading the new crom as I type this!
06 QC SLT Big Horn Hemi 2wd 20's,3.92's, Magnaflow, custom Y, Diablo, Edelbrock Shorties, modified K&N CAI.
14.64 @ 90.5 mph (short belt, no spare)
93 Stroked and Blown Mustang
10.84 @ 128.5mph
07HemiR6
Post by 07HemiR6 »
johan wrote:We can do prime delete on 07 and 08 models right now, anyone wants one shoot me your last tune written.
So you have this straightened out now with the new crom? What was the deal with the 9t02d crom and prime delete?
07 Ram 1500 QCSB Sport 4x4 Hemi
TTI Headers, y-pipe w/ high flow cats, Magnaflow Cat Back
BETHALHEMI
Post by BETHALHEMI »
05 I tryed the new crom w/good results on the performance of the truck.Only problem is I still am having the key recognition trouble after the new program has been written to the truck.The pred does not see the key as on but the new tune does write to the truck.Before it would make me go back to stock and start all over.looks like you allmost got it.This was w/the new beta put out yesterday.All in all truck runs GREAT.
HemiHorsePower
Re: New beta for unsupported 04 and 08, tune changes as well
Post by HemiHorsePower »
johan wrote:http://diablosport.com/downloads/predat ... xport.crom
*support for the new 04 and 08 calids
*Tune changes for ALL years for better shifts
*tire size change and key cycles issue resolved
Try it and let us know.
for "better shifts", do you mean no tourque mangmt? It seems that s/c completely removed the "mush"(t/m) or more throttle response in part throttle like s/c has?unloaded the gear in back , cable, ladders etc. and now from a stop, it'll smoke the tires into 2nd gear no prob, burries 120 at high 4rth and drops into 5th still digging. very happy with the first tune, just would like to get rid of the "mush" while driving non wot,tried your first beta v.o2 and was fine except for the surging idle, so put it back to v.01, does this new version, v.02f address the surging idle , or stabilize it? finally got my low end ive waited 2 yrs for. worth it. just trying to work out a few bugs and we'll have it.
thanks
hh
06 Ram 1500, LT Headers with Gutted Cats, Spartan Cam, CNC Heads W/ 6.1 Pushrods, CAI, 180*Therm, Magnaflow 40 series, Innovate Wideband, Flex-a-Lite E-Fan, Sharadon Stage 3 Valve Body, APS 2400 Stall T/C, DS U7137.
Gr8ridn
Post by Gr8ridn »
I just got my Predator and installed the 87 High Performance Tune with no issues from Rev 9r01. I also modified it to de-active MDS. I am very pleased how everything is running. I can feel the extra power and throttle response along with better shifting.
I plan to try the 91 tune when I have used up my tank of 89 fuel.
Do you plan to issue this beta as a regular revision once you are satisfied all is good? I am not real keen on trying a beta when everything is good right now.
Last question, when I switch to the 91 tune will I have to load the original tune first or can I load directly to 91 from the 87 predator tune?
Great Product.
2007 Hemi Quad 2WD Sport
Bilstiens, Front/Rear Bell tech Sway Bars
Rear Level Kit
Predator!
Kern Valley CA
~RAM~
Post by ~RAM~ »
thanks
hh
HH the new crom made my truck run a lot better I too now burn into second, an the shift is much better with this update, but I didn't kno they could change the part throttle "mush" it would be awesome if they could.
What do u mean by idle surge?
2005 Ram 1500 QC 5.7.
K&N cold air intake, LT headers, 2.5" true dual exaust with no cats...
HemiHorsePower
Idle Surge
For my truck, factory idle is at 500 RPM. For some reason, the first beta update would cause the idle to surge or slowly rise to 700 rpms, then if i tapped the gas, it would return to 500 RPMS. It seems that wot is great, but everything below that, it seems like it takes 2 clicks of the gas pedal for 1 click on the throttle body. When I had the S/C tune, for partial throttle, it had much better throttle respone, and it had totally removed the tourque managment, much better shifting. I'll except what i have, I"m just wondering if they are addressing that.
But all else it great , very happy with the tuner and the trucks performance.
~RAM~
RE: Idle Surge
Post by ~RAM~ »
I see. ,that would be nice to have on the pred.
When I do like second gear pulls from around 35 mph it feels as if somtimes if I hit the pedal around 3/4 of the way, rather than to the floor, it pulls harder, or seems when I'm at WOT it bogs. For some reason.
Speed1B
RE: Idle Surge
Post by Speed1B »
I have an 08 and would like to try this update. Do i have to put my shift points and my fuel/spark settings in again when i update it or will the predator remember it? Also do i have to go back to stock before the update?
Sorry if these are basic questions im just a newb and dont want to F anything up.
'11 Hemi QC 4x4 Sport
Magnaflow Exhaust
Airaid Filter
BMRbrnSNRbrd
RE: Idle Surge
Post by BMRbrnSNRbrd »
Wow, all this updating and all I want is shift point control for my '04....can anyone tell me if it's at least being worked on?
'04 Dodge Ram Hemi QC
Predator U7137, 4.56s,Thorley Tri-Y Headers/Y-Pipe, Magnaflow Muffler & HiFlow Cat, Mark VIII E-Fan, 180 Stat, 8.2mm Wires, NGK 5306 Plugs, C.A.I, Optima Yellowtop, Trans Resistor mod
johan
Re: Idle Surge
Post by johan »
HemiHorsePower wrote:For my truck, factory idle is at 500 RPM. For some reason, the first beta update would cause the idle to surge or slowly rise to 700 rpms, then if i tapped the gas, it would return to 500 RPMS. It seems that wot is great, but everything below that, it seems like it takes 2 clicks of the gas pedal for 1 click on the throttle body. When I had the S/C tune, for partial throttle, it had much better throttle respone, and it had totally removed the tourque managment, much better shifting. I'll except what i have, I"m just wondering if they are addressing that.
So you say before the beta your idle did not do this?? I did not make any changes that would affect that between the two.
Is it possible it happens right after you install the tune and then it gets better?
If that is the case i would understand why as whenever you flash the truck the learned adaptive's get reset and needs to relearn.
This will be more pronounced with more mods.
If you want, e-mail me your last tune written and we can try some stuff.
Diablosport INC
johan
Post by johan »
Gr8ridn wrote:I just got my Predator and installed the 87 High Performance Tune with no issues from Rev 9r01. I also modified it to de-active MDS. I am very pleased how everything is running. I can feel the extra power and throttle response along with better shifting.
Great Product.
No need to go back to stock when switching tunes.
I am getting ready to release a new production version here shortly.
Diablosport INC
