KPA to PSI???
General Trinity Support
sfla_srt4
KPA to PSI???
Post by sfla_srt4 »
how do you convert the KPA reading to a PSI reading?? The map is shown in the KPA form and im trying to figure out how to read it as PSI.. Thanks!
RE: KPA to PSI???
http://www.csgnetwork.com/presskpapsicvt.html
To convert kilopascals to pounds per square inch, multiply the kpa value by .14503773773020923
sfla_srt4
RE: KPA to PSI???
Post by sfla_srt4 »
Then the values are wrong on the trinity... When I put the boost gauge around "0", it says ~100Kpa... Could you guys look this up to see? When im crusing on the highway, its around ~65Kpa, and im in vac, deffentily not 9lbs of boost lol..
RE: KPA to PSI???
0 Boost is atmospheric pressure, which is 14.7 psi....so, 100kpa x .1450377=14.50377, right about 14.7 psi which is atmospheric...
sfla_srt4
RE: KPA to PSI???
Post by sfla_srt4 »
ahhhhh thanks then.. Forgot about the baro.
parsonsproject
Post by parsonsproject »
So is there a way, using MAP kPa, baro, and whatever other readings, to get a value in psi which is the actual psi being sent into the manifold? Is there another value to log which I am missing? My obd2 aeroforce interceptor scangauge is able to do it.
04 neon srt-4
ChrisMyers1
Post by ChrisMyers1 »
Is this possibly a dodge related issue showing atmospheric?
06' cummins, Trinity Beta tester, Extreme power puck, ETC.
2 of those shiny spinny things..
Yeah, it is simply the way the factory PID works.
I was logging our Duramax this weekend and it shows actual PSI with 0 being atmospheric.
Return to “General Trinity”
