How does the Predator make the power???
Dodgezilla
Post by Dodgezilla »
Is there somewhere I can go to see just how each level makes it's power. I'm wanting to know which settings do Timing, Pressure, and/or Duration and just how much.
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
duallydave
RE: How does the Predator make the power???
Post by duallydave »
i think diablo keeps thier info to themselfs,others have asked and got no reply,they do say the extreme tunes have timing but they wont say how much,im not sure if other manufactures give out thier "secrets"or not but im sure they wont here,i dont care how they make the power im just glad they do
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
roberts
Post by roberts »
:evil:
johan
Post by johan »
Yeah, we do not like to give specifics on the tuning for obvious reasons.
Nothing personal.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Dodgezilla
Well, I'm not asking how you do it. I would just like to know if I'm pushing the limits of my stock fuel system by running certain programs....
Oh well, the truck runs awesome so I will just live with it. Someone will figure it out eventually...... ;)
johan
Post by johan »
I would say you are definitely pushing it with the ext RKL tune, fuel system and trans. Both extreme and ext RKL are pushing trans post haste to an early grave, but we all kind of know that.
Fuel wise, especially if you stack the rkl is right on the limit.
Diablosport INC
Dodgezilla
Got it. ;)
I'm getting my new clutch this weekend so I'll be fine in that department. I'll be on the dyno at the end of the month and I'll probably try the Extreme tune but I'm not sure about the RKL tune. I don't want to hold the dyno up for 10 minutes while I change tunes.....
duallydave
try dynoing the ext rkl and load it before you get there,another member here dynoed the reg extreme and got 430hp with no puck and that was on a 305hp.im curious about the rkl
Dodgezilla
I think I remember reading something about very high rail pressure while running the Extreme RKL tune. Is that right? If so then I don't want to chance it while I'm 125 miles from home. I'm also still running the stock LP and I don't know if it will push enough fuel for that setting.....
duallydave
you may be rite,ive been running extreme rkl and i thought i was having wastegate problems but im sure im out of fuel,guess i need a fassssssss
Blue2003
Post by Blue2003 »
duallydave wrote:you may be rite,ive been running extreme rkl and i thought i was having wastegate problems but im sure im out of fuel,guess i need a fassssssss
no guessing to it. a clutch is a must for the extreme stacker mode. i would get the h.p.f.p 150 gallon fass before i ruined a day @ the rollers. just change to that pump and you will feel a difference. even with your truck in the stock mode. i would also recommend gettin' rid of the 1/4" line that runs from the bottum of the fuel filter housing to the injection pump. replace it with a 3/8" line. that helps get more fuel to the pump. replace those two items and your good to go. you will not have to worry about running the rail dry.
duallydave
cool thanx for the tip,ill try the 3/8 line first,my liftpump is in the tank{waranty thing}maybe ill add a pusher like a holley.
trik396
Post by trik396 »
An educated guess tells me that most programs are timing and duration only. The extreme tunes probably add pressure. Some guys need to take heed when stacking a Diablo with something else that adds timing like Juice. Excessive timing can and will destroy things... very expensive things.
I'd get a Walbro before a Holley. Much better pump for the same price. Maybe less....
Blue2003
Post by Blue2003 »
trik396 wrote:An educated guess tells me that most programs are timing and duration only. The extreme tunes probably add pressure. Some guys need to take heed when stacking a Diablo with something else that adds timing like Juice. Excessive timing can and will destroy things... very expensive things.
here is a reason to buy a fass. 6 year warranty. do not know about the others?
'03 6-speed, afe stage 2, ats arc flow, 4" str8 threw exhaust,Smarty/Puck, TST PMCR R37, Fass 150, SPS 62/14,60# boost,1600*pyro gauges
modified03
Post by modified03 »
i'v got a carter pusher pump on mine till i get the money for a fass. Carter is fine right now i'm pushen like 22/18. Carter is also a diesel pump and the holley isn't.
