I have a 125 Zex Kit I'm installing today.
I have the NGK 2314.. but I can't get the A/F Down in the 12's..
At idle she's at A/F is 14.9 and then at WOT come down to 13.5 or so...
I'm getting 3.5 ST and 6 LT KNK with 91CAI tune
Please Help...
Nitrous and ST knock Retrad
Dan Ramsey
YWait System Services Inc
09 Chally RT Auto
Mods: Ariaid CAI, 180 Stat, Sock XPipe w/ Magnafows and 93CAI Tune
09 Chally RT Auto
Have you added fuel?
If so, how much?
If so, how much?
no I have not yet...
How much should I start with?
Dan Ramsey
09 Chally RT Auto
09 Chally RT Auto
going to changes the plugs first
Dan Ramsey
09 Chally RT Auto
09 Chally RT Auto
Wow, you may want to consider some custom tuning from a CMR dealer, as you are about to get into trouble.
You need to get the WOT A/F right before you spray it, and you also want to get rid of that KR before you consider spraying as well.
Yes I have not installed the zek yet just changing the plugs..
Tune the knk out after new plugs... NO ????
Dan Ramsey
09 Chally RT Auto
09 Chally RT Auto
Which is the TPS wire for output.. I installed the kit last night.. I put the resistor in line with the white wire from the zex box..
Finshed the A/F it at 13, WOT it drops to 12 and 11.. 91 CAI tune and WOT spark retard set at 6 put I have the 125 jets in place..
Which wire do I splice into The install doc says BROWN w/ ORANGE STRIPE but there isn't one on the 09 or I went color blind..
Please help
Please help
Dan Ramsey
09 Chally RT Auto
09 Chally RT Auto
ok I've been up to long... Cleared the codes everything is good.. I had the right wire once I looked at it again after the sun came up.. I need better lighting..
Anyway thanks...
Anyway thanks...
Dan Ramsey
09 Chally RT Auto
09 Chally RT Auto
