u7194 speed limiter
u7194 speed limiter
u7194 2008 silverado how do I disable speed limiter on performance tune
RE: u7194 speed limiter
Go to the modify tune menu and turn off the speed limiter.
Do you have to go into the performance tune first and then modify the speed limiter ? Or can you modify directly from the main menu?
Slp Diablo Predator. SLP7196. 2001 Pontiac Firehawk Trans Am. Slp lid, Slp dual-dual catback.
you have to select the same tune you installed before... then go to Modify Tune (instead of install tune)... scroll down to the parameter you want to adjust, press the center enter button to access it, make your adjustment, press the center enter button to save the change, then press the ESC button a few times to back out of the menus until it prompts you "Install Tune Now??" - select YES and it installs the tune with the changes you just made.
Ok but I just don't see one for speed limiter. Not that it matters really since the top speed on these cars is often upwards of 160 mph. But still would like to know why I can't see it.
the adjustable parameter doesn't exist separately for yours, because the speed limiter is already removed in the canned tune itself...
it's not for the trucks, so that's why he has the option available to him..
badsierra04
So how do I go about changing my speed limiter on the U7193? I know I could probably play around with the programmer and figure it out, but I'm afraid of what all I may screw up in the process.
04 Sierra Z71 5.3 with Volant CAI Flowmaster American Thunder cat-back and Diablo Predator tune.
jdsilver07
Can you disable the speed limiter, then export the last tune written and post it here please?jdsilver07 wrote:when i remove my speed limiter my abs/brake lights come on, i havnt adjusted tire size and it doesnt happen with the speed limiter on with the diablo tune
