stock srt-4 overboosting on 93perf tune.
derr12
Post by derr12 »
I have an intake and the mopar rice plate (noisemaker), and an oil catch can.
other than that, im bone stock. running 94 octane chevron fuel.
before winter i loaded the 93 octane tune with limited success, had a little knock up top, but other than that....
this spring i loaded the stock tune so i could update firmware on the dsport.
re-loaded the 93 tune. and now i spike to 20 psi in second, more in 3rd gear. i let off right away cuz that's too much boost.
half a tank of gas and the pcm still hasnt "learned" so i pulled the neg terminal for a half hour. Same thing.
only difference from before winter was the firmware.
any ideas?
derr12
RE: stock srt-4 overboosting on 93perf tune.
Post by derr12 »
oh forgot to mention it's a 2005 model srt-4
derr12
Post by derr12 »
i can log a run if you want, but i wont go wot for long for fear of engine explosion @ 21psi. i have the unit updated to u7134-9r17.crom.
1srt4me
Post by 1srt4me »
I had the same problem. Re-load the stock tune back in. Disconnect the negative battery cable for 10 to 15 minutes to clear the computer. Then re-load the 93 tune again.
derr12
Post by derr12 »
did that yesterday, didnt seem to help. the one thing i do notice tho is that the boost comes on a little less strongly till just after 4000 rpm, and then it spikes to 19-21+ psi.
somethings funky. there sure are a lot of optiosn to log for. experts, if you are intersted in looking at this for me, what perameters would you like me to log for you?
johan
Post by johan »
Post up your last tune written so i can take a peak at it.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
derr12
Post by derr12 »
thanks, here you go.
93tunederr12.drg
last tune.
(2.25 KiB) Downloaded 222 times
derr12
Post by derr12 »
ill xpresspost a free taco to the first person that suggests an idea that fixes my issue. driving around and not going WOT on an srt-4 is like hopping around with 1 leg.
sfla_srt4
Post by sfla_srt4 »
well the only ones who can help you are the Diablo guys, they can only read and change your last tune...
derr12
Post by derr12 »
so you don't like taco's then? :p
derr12
Post by derr12 »
bump
Letxen3
Post by Letxen3 »
when was the last time you had a boost leak test done? stock boost levels may be fine and wont over boost, but if you have a boost leak that leaks at lets say 16 psi the wga duty cycle with the 93 tune maybe trying to over compensate for the leaking boost and causeing a over boost.
21 psi spike in 2nd gear is fine, thats what i run. long as your not lean. do you have a wideband? also what is your boost like in 3rd gear? also can you post a log.
also do you have a 30/30 boost gauge or the factory 30/20?
~James 2004 PT Cruiser GT
johan
Post by johan »
Give this one a shot. there where some discrepancies in the tune you sent me.
93tunederr12_mod.zip
(55.9 KiB) Downloaded 277 times
Diablosport INC
derr12
Post by derr12 »
A thousand thankyou's johan! Will give it a try after work and let you know.
derr12
Post by derr12 »
ok, let it warm up and then here is what i logged. so far looks like the bugs are worked out. no more than 15psi for the gears i went thru. here is my log:
I think im good to start tinkering, out of curiosity, what did you find that struck you as odd?
