I had the same issue with mine my ABS light comes on after 4-5 miles of driving. I have the U7193 with the latest update. Changed my tire size and now the light comes on. I am running 37/13.5 MT on a GMC 2500HD 6.0L.
From what everyone has posted they have gone in and changed the tire settings till they got the right settings to keep the light from coming on. I do that and it throws off my speedo and all the other stuff tied into it (MPG,Odometer,ect.).
I have the Basic Diablo tune installed the only change was the tire size tried installing the tune both ways standard and metric. I love the added power it gave but do not like this ABS issue. The only performance parts on the truck is a cold air intake and I have 9" lift with 37" tires.
GMC04
Try setting the tire size in the metric version manually, Then start working your way down on the size. (Like if stock is 250/70/17 try setting it at 250/68/17 then ***/67** and so forth)
when adjusting these tire sizes make sure to follow these steps.
1- boot up programmer
2- pred tune- Modify parameters
3- reset parameters to stock
4- install reset program with no changes to program
5- start vehicle and let it run for a minute or two (i did this while rebooting the programmer)
6- after rebotting it select program to install
7- modify the program parameters making adjustments to the wheel size
8 -then load the program.
I found that if you just start changing the program parameters without resetting it and starting the vehicle the predator starts changing / converting some setting back to stock.
Again I'm no pro at this programming I can only let you know what I did and how it turned out for me.
I would start my setting at 1 point above my stock and start working my way down until you get it.
2007 Silverado
4.8 w/3.23 Gear
Volant Cold Air Intake
Vette Servo
40 Series Flow Master
7194 9r07
