08 ZO6 Custom tune
alssiri
08 ZO6 Custom tune
Post by alssiri »
Hi
I have the U7194 for 2008 ZO6 & need a custom tune for these mods :
-Kooks LT's with high flow cats.
-Vararam induction.
Having rear O2's light coming on alway's too after the headers install.
Ahmad
neonhomer
RE: 08 ZO6 Custom tune
Post by neonhomer »
You will need to post your current tune and the backup file for it to be modified into a custom tune.
NeonHomer
1996 Jeep Grand Cherokee I6 4.0
alssiri
Post by alssiri »
Sorry ! Here is the original backup file & the mod :
-Vararam cold air.
-Fuel used is 93 ( they say its 98 ) octane.
P.S : Check engine light is on cause of rear O2's.
Predator U7194 v.9r05
2008 Chevrolet ZO6
Ahmad
alssiri
Post by alssiri »
Please :mrgreen:
Also the modify tune featur is not working !!
yeah, all you need is a custom tune to disable the codes... nothing to do for the vararam intake - you need to adjust your fueling yourself for that...
you need to do some normal steady driving/cruising data logs to see where your average LTFT's are at and then adjust your injector slope accordingly...
here's info:
alssiri
Post by alssiri »
Any news regarding the modify tune feature & the Custon tune.
Ahmad
which tune file is that that you posted?? is it the orignal backup or is it the copy of the diablo tune outta your car??
you need to copy the current diablo tune outta your car and post up that file... here's info on how to do that:
http://diablosport.com/index.php?name=P ... pic&t=6547
alssiri
Post by alssiri »
Here is the Diablo preset tune.
alssiri
Post by alssiri »
Hi
Any good news regarding the modify tune option yet & the custom tune :)
Ahmad
what revision is your predator on?? first time I've ever heard of an 08 vette predator not having the modify tune option...
you would select the same tune you previously installed, and then you get to another menu that has Install Tune or Modify Tune...
alssiri
Post by alssiri »
I have Predator U7194 v.9r05 & when going to modify tune i get the " can"t modify parameters " message & i think there is 2 more posts regarding the same issue i think one is by "schnitzer "
Ahmad
schnitzer
Post by schnitzer »
alssiri wrote:I have Predator U7194 v.9r05 & when going to modify tune i get the " can"t modify parameters " message & i think there is 2 more posts regarding the same issue i think one is by "schnitzer "
Ahmad
Yes common guy's. 1 month that I ask you to check my problem!!!
alssiri
Post by alssiri »
Guy's :cry: We know you are working on it :D but can you at least tell us where are we at 8)
Ahmad
alssiri
Post by alssiri »
update your 7194 predator to a newer revision...
http://diablosport.com/downloads/predat ... -9r07.crom
make sure you restore your original backup to your car first, before you update the predator.
