03 Cobra "Did not detect ignition"
LineC
Post by LineC »
Went to install the Diablosport performance tune and having a little trouble. It won't save my stock tune and when it goes from "turn ignition off" to "turn ignition on" it recongnizes that I turned my ignition on but tells me it can not detect ignition. Then tells me to check for an aftermarket chip. I know there isn't an aftermarket chip.
What gives? :?
2003 Mustang Cobra Convertible
Predator U7142
7r12D
RE: 03 Cobra "Did not detect ignition"
If there is no chip, are you sure there is no tune on the PCM other than the factory Ford tune?
LineC
Post by LineC »
There is no chip and no other tune. Just to make sure my buddy brought over his Granatelli Fuego and uninstalled it off his car and installed it on mine no problem. We uninstalled it off my car and still no go with the Predator.
There has got to be something else going on here. I bought the car from a friend, after he got a GT500. I know for a fact there was never a chip or tune installed in it.
spp114
Post by spp114 »
When you turned the key "on" did you turn the key to the second click just before the starter engages? I was a little unclear when I loaded the program.
LineC
No GO
Post by LineC »
No I am sure on my key positions.
Ahh the 4th of July and I can't drive my Cobra. Ohh well my Camry is just as fun.
Diablosport I think I need my tuner reflashed.
Ohh ya does your factory HP tune fix the problem Ford had with the car stalling out?
kmac1
Re: No GO
Post by kmac1 »
LineC wrote:No I am sure on my key positions.
Do you have any aftermarket electronics on the car? I had an issue like this on a car with NEXUS guages and I had to wait for them to power down completely after I turned the key to the off positon. They had a delayed shut off that back fed power to the car and the Predator never saw the key cycling. Just a thought!
Kevin@DiabloSport
LineC
RE: Re: No GO
Post by LineC »
Car is stock except for an KN intake and Dynomax cat-back.
I don't understand why the Fuego would work and this won't.
It senses something because when it tells me to turn key to ignition there is no hitting continue it just waits for me to do it. As soon as I do it, thats when the message comes. If I don't do anything no message ever comes. It just says something along the lines of turn key to ignition.
I just need to know what are my options on this thing. Obviously your product works on Cobra's I see it everyday. I ethier have a defective unit or my car is defective.
I bought this thing awhile ago and waited for my warranty to expire. Warranty expired now I tried to use it and no-go.
If I call in is there something we can do over the phone?
Ohh ya last tune written is original backup so I know it isn't locked.
kmac1
Re: RE: Re: No GO
Post by kmac1 »
LineC wrote:Car is stock except for an KN intake and Dynomax cat-back.
Yeah bud, Please call in first thing in the morning. Try to have the Predator hooked up to the car when you call.
Thanks for your patience!
Kevin@DiabloSport
LineC
RE: Re: RE: Re: No GO
Post by LineC »
Just to update everyone. Called today and confirmed I was doing everything right. Still no go. I need to RMA this thing back but wife bought it for me as a Xmas gift and I waited for my factory warranty to run out. Well long story short I have no receipt and the wife doens't seem to remember where she got it from online. I tried to reflash the thing last night with DS downloader and it keeps failing on packet 2. So now everytime I boot this thing up it says it's missing it's operating system. Ohh ya and the screen is really dark and can only be seen at an angle. This thing is F-up bad. So I open up the connector end to make sure the wires and still soldered. Everything looks good no burnt up stuff or broke wires.
I am calling it quits since I don't want to spend 100 dollars extra, after the wife paided around 380 she said. I got no uses out of it and now its totally useless and won't even read trouble codes. If anyone wants it, it will be in the trash can probaly on Monday come by and grab it. Hell even if it works I don't think I want this particular one installing fuel maps on my Cobra. Probaly fistle-fart halfway through and not let me install the original back on. Rendering my car and predator close to the same, useless.
Lesson learned keep receipts.
Am I the only one with problems like this???
spp114
Post by spp114 »
I too have a 2003 cobra and fortunately didn't have any problems with the install. Each programmer has a serial number so Diablosport should be able to verify the time frame when sold and which vendor it was sold to. Maybe you could then contact the vendor or a least get a receipt.
Either way, Diablosport made the unit so they should be willing to exchange it for a new / refurbished unit.
kmac1
Re: RE: Re: RE: Re: No GO
Post by kmac1 »
LineC wrote:Just to update everyone. Called today and confirmed I was doing everything right. Still no go. I need to RMA this thing back but wife bought it for me as a Xmas gift and I waited for my factory warranty to run out. Well long story short I have no receipt and the wife doens't seem to remember where she got it from online. I tried to reflash the thing last night with DS downloader and it keeps failing on packet 2. So now everytime I boot this thing up it says it's missing it's operating system. Ohh ya and the screen is really dark and can only be seen at an angle. This thing is F-up bad. So I open up the connector end to make sure the wires and still soldered. Everything looks good no burnt up stuff or broke wires.
LineC, When you install the update make sure the baud rate is 57600. If it says "application missing or corrupt" you just need to reload the .crom file and it will be back to normal. I am not sure of the strategy on the fuego but the Predator verifies the pcm is stock before it will allow itself to flash the PCM and that may be an issue. I have seen other brands of tools leave what we call "watermarks" in the stock file when they return the car to stock and this will create an issue when you try to load a Predator onto the car. I don't think this is your issue but it may be the reason the fuego worked. We rarely hear of issues like this considering the volume of Predators on the market, so don't feel like it is a characteristic of the product. They are quite reliable. Please do whatever you can to find that receipt and get that Predator sent back so we can fix you up!
Sorry for all the inconveniences this has caused you,
Kevin@DiabloSport
LineC
RE: Re: RE: Re: RE: Re: No GO
Post by LineC »
Just to make sure I do this right. I should select my baud rate to 57600? I have been selecting 115200 as in the directions in the .pdf file.
Just tried what you said and nothing at all now. Always getting failed downloads. No waiting on packet 2 just immediate fails. Actually when it fails on packet 2 it says "can not load Ford Gas application into Cobra tool"
Any idea why my screen now is almost completely black?
No no hard feelings, this isn't nearly as bad as my Megasquirt Datsun. (muffled laugh)
Does an Ebay invoice count as a receipt? She said she bought it online through ebay and it came in a new box but I dunno if he was a authorized vendor. I can pull that through my history but his packing receipt is long gone.
If not I am probaly gonna try to find a SCT. Just one of those things I am sure this is a great product and you all have been quick to offer help. Just don't like this thing at the moment.
Sounds like you may be using the wrong .crom file.
On the downloads page of the U7142 it tells you which .crom file you should be using based on the tools bootloader.
It sounds like you should be using the 7r12d file for use with tools that say 'booting cobra'.
kmac1
Re: RE: Re: RE: Re: RE: Re: No GO
Post by kmac1 »
LineC wrote:Just to make sure I do this right. I should select my baud rate to 57600? I have been selecting 115200 as in the directions in the .pdf file.
LineC, Yes it sounds like you have the wrong file. My bad, I should have asked about that! Somehow there are two bootloaders for those tools and you need to load the Cobra bootloader file located here.
http://www.diablosport.com/index.php?mo ... lay&pid=12
However, if I were you I would search for some proof of purchase even if it is the Ebay records and contact our sales department. Just tell them this is the first time you have tried to use it and the screen is black. It sounds like it is almost unusable based on that issue alone. I'll refer them to this post and they'll be able to see the troubles you have been through and hopefully we can get you fixed up!
Kevin@DiabloSport
kmac1
Post by kmac1 »
LineC, An Ebay invoice qualifies as a receipt, if you can find it tonite call Abby at her direct line first thing in the morning @ 561-961-2400 and she can tell you if they are an authorized dealer or not and hopefully help you out.
Kevin@DiabloSport
Return to “Predator Ford Gas”
