9r10 for the 6.4 guys is up and ready for download
- pic350ford
njk350 wrote:Pic, just for comparison, are you driving an 08 Crew Cab?
That's what I'm running and your mileage is much better than mine.
Njk my truck is same as yours , 2008 full four door. got 4" pipe
strait out from particulate filter . running banks intake system .
other then that truck is bone stock, except for diablo tunner.
like i said , i do mostly highway driving with my truck to get the 16.3
out of her. if i start fooling around and wacking the petal , milage
falls right off. But i am ok with that. i just love the power to
roll by the smoke blowing duramax and cummings guys.
ITS THE BEST ha ha But most of the time , i drive fairly
moderate. this truck is my princess,and done want to hurt her.
- pic350ford
Thats the same calid as the DISperformance truck, and he just sent them a new tune...WildBill wrote:Hey Don,
Any ideas on when you might have something for the yf series?
Don,
Hoondog here. Running the economy tune you sent me via e-mail and so far I seem to have lost about 1 mpg (down to 16ish, note I don't push my truck that hard ) at 70 mph totally stock empty. Driveability is much better as far as shifting but the take off is sluggish like the turbo isn't wanting to spool up off idle, I don't know if that is a characteristic of the economy tune or not. cruise works fine, no bucking noticed, boost seems to come up quicker with less pedal movement while cruising at freeway speeds. I still prefer the old tow tune at this point ( better throttle response on the bottom end in my opinion). I will run the economy tune through this coming weekend and keep you posted.
Hoondog
Hoondog
I wouldn't mind trying this new extreme tune out as well.SCGt94 wrote:Pic geting ready to send you another tune..extreme. Has the new 10lbs added and the timing changes for the highway.
Thanks for the help pic, i'll call ford in the am!!!pic350ford wrote:joestroo Have you had the egr valve replaced????? I am on my third one, I had ford tell me that it was fine ..... I removed it
myself ,and it was stuck in postion. was running 20psi @ 75 mph before i changed it, now i run no more then 10 psi
running the same speed... I am running newest extreme tune from Don.. Milage after two tanks of fuel is showing
about 16.3 mpg. Thats up from stock at 14.1 . I couldnt imagine the economy tune getting less milage!!
F2504myTIGE
