Diablo intune freezing up
Esprit6286
Re: Diablo intune freezing up
So I went to program the 93 octane tune and it got to 15% and froze. Than " service stabilitrak" light came on. I called Diablo and after 25 min on hold I gave up and turned the key off. When restarted every light on the dash was on and I was able to get it home but in like a limp mode. Luckily I plugged it back in and returned the stock tune and it's fine. I'm too nervous to try again. 2016 Silverado 5.3
could there have been a low voltage situation?
06blackgxp
I'm having the same problem with freezing trying to tune? I started to tune my 07 Escalade and it was at 100% and said something to to effect of experienced an error. Since then I can't get into tuning mode. When I select tune vehicle it starts to spin then freezes up spins again for a second then freezes completely. Registry reset key is 873263 D4071C 5C2520 41A414 671D4F. Thanks!
please post the backup files from the device before we reset it.06blackgxp wrote:I'm having the same problem with freezing trying to tune? I started to tune my 07 Escalade and it was at 100% and said something to to effect of experienced an error. Since then I can't get into tuning mode. When I select tune vehicle it starts to spin then freezes up spins again for a second then freezes completely. Registry reset key is 873263 D4071C 5C2520 41A414 671D4F. Thanks!
06blackgxp
Back up files
- TCM_24242131_Backup.grg
- (39.08 KiB) Downloaded 265 times
- ECM_12614104_Backup.grg
- (61.49 KiB) Downloaded 265 times
I'm having the same problem with freezing trying to tune? I have on occasion needed to charge my battery before or after tuning/retuning. Is this a possible problem?
- TCM_24237497_Backup.grg
- (13.29 KiB) Downloaded 263 times
- ECM_12614095_Backup.grg
- (52.6 KiB) Downloaded 313 times
- info.xml
- (2.08 KiB) Downloaded 260 times
go to settings/advanced/registry reset and type out the key it displays and post it up, and leave tool on that screen until I reply with instructions to proceed.06blackgxp wrote:Back up files
please start a new thread, it gets hectic trying to post files for 2 different customers in the same thread.josh6980 wrote:I'm having the same problem with freezing trying to tune? I have on occasion needed to charge my battery before or after tuning/retuning. Is this a possible problem?
06blackgxp
DD47BD FAFB41 20B2AA 00C5AA 3E8798mikel wrote:go to settings/advanced/registry reset and type out the key it displays and post it up, and leave tool on that screen until I reply with instructions to proceed.06blackgxp wrote:Back up files
click next then enter this06blackgxp wrote:DD47BD FAFB41 20B2AA 00C5AA 3E8798mikel wrote:go to settings/advanced/registry reset and type out the key it displays and post it up, and leave tool on that screen until I reply with instructions to proceed.06blackgxp wrote:Back up files
C868E27B877493B9
then Ok and it will reset.
06blackgxp
I did the reset now it wants me to email the stock tunes. I have them listed up a few posts
save this to intune drive and let tool import it then go to the vehicle and click tune vehicle and it will load this t set pcm back to stock,then we may have to repeat for tcm.06blackgxp wrote:I did the reset now it wants me to email the stock tunes. I have them listed up a few posts
- CTRL_12614104_UPDATE_1GYFK66837R395828.grg
- (57.4 KiB) Downloaded 280 times
06blackgxp
Back up and running. Amazing what the tune did for it, Thanks!mikel wrote:save this to intune drive and let tool import it then go to the vehicle and click tune vehicle and it will load this t set pcm back to stock,then we may have to repeat for tcm.06blackgxp wrote:I did the reset now it wants me to email the stock tunes. I have them listed up a few posts
